Εταιρεία κατασκευής λαμπάτων ενισχυτικών
Six tube line stage preamplifier that provides exceptional musical performance unmatched anywhere near its price. The LA-100 offers harmonic integrity, spatial dimension and coherence with a beauty of tone that making it a price to performance triumph. Music lovers only requiring a line stage need to hear how much musical beauty this unit can access. The LA-100 is hand-built with care and pride creating a component that will faithfully and beautifully reproduce music for years to come.
Specifications
Input Impedance 20,000 Ohms
Output Impedance < 300 Ohms
Distortion < 0.1% @ 5 volts into 5,000 Ohms
Gain 11dB
Tube Complement 1 - 5751
1 - 6350
2 - OA2
2 - 6EM7
Weight 20 lbs.
Power Consumption < 50 watts
Power Storage 100 Joules
Dimensions Width - 17 inches
Height - 5.25 inches
Depth - 12 inches
Channel Separation > 75dB
The OPS-1 & 2 with separate power supplies are complete phono stages offering the committed vinyl enthusiast the platform
of choice for playing records. Medium and high gain, for moving magnet or moving coil cartridges, all tube power supplies and
the option of a volume control and remote volume control, they can be complete, single function preamplifiers for the ultimate
playback of records. They can also be used with a line stage preamplifier. These extraordinary phono preamplifiers are hand-
built for a singleness of purpose. If you only play records and you love the music in your record collection, the OPS-1 or 2
(the OPS-2 is full dual mono construction) with a volume control is the purest path those notes can take.
Specifications
Gain Selectable High 62dB / Low 36dB
Input Impedance High / Low 47,000 Ohms
Alternate loading available
Output Impedance 1,000 Ohms
Output Voltage 7 Volts into 5,000 Ohms
Equalization RIAA +/- 0.5dB
Noise -60dB @ 2 Volts Output
Weight Phono Stage - 10 lbs.
Power Supply - 15 lbs.
Dimensions 100 Joules
Height - 4 inches
Depth - 9 inches
The VZN-100 monobloc amplfiers are our original core design and are 100 watt materpieces. Seen at hi-fi shows for years, and garnering great praise we might add, the Marquis are simply perfect for moderate size systems and speakers. They deliver amazing punch along with a transient speed that is breathtaking while remaining unfatiguing for the committed listener. Highly resolving and harmonically full, this amplifier begat the Joule reputation for performance, beauty, and value. It is a beautiful amplifier in the fullest sense of the word. Available in standard construction or music-wood with automotive finish.
Specifications Per Channel
Tubes 6 - 6C33CB's Triode (Output)
2 - 6350's Dual Triode (Driver)
1 - 12AX7's Dual Triode
2 - 6DJ8's
(Differential Mu Stage)
Power Supplies 2 - Regulated Filament Supplies
1 - Regulated Driver B+ Supply
1 - Driver Negative Supply
2 - Floating Driver Bias Supplies
2 - Floating Driver B+ Supplies
1 - Driver Filament Supply
1 - Floating Meter Supply
Power Output 100 watts Class A into 8 Ohms
80 watts Class A into 4 Ohms
Output Stage Single-ended asymmetrical Class A
Power Requirement 400 watts each monoblock
Weight 40 lbs. each
Dimensions Width - 12 inches
Height - 9 inches
Depth - 18 inches
![](/forum/proxy.php?image=http%3A%2F%2Fwww.joule-electra.com%2Fimages%2Fla100.jpg&hash=943407bac9f76d8e9f140b94cfe47c5b)
Specifications
Gain 11dB
1 - 6350
2 - OA2
2 - 6EM7
Weight 20 lbs.
Depth - 12 inches
![](/forum/proxy.php?image=http%3A%2F%2Fwww.joule-electra.com%2Fimages%2Fops.jpg&hash=e1e8b4d85ea8cd491ece03b6bc08f6e7)
Specifications
Height - 4 inches
Depth - 9 inches
![](/forum/proxy.php?image=http%3A%2F%2Fwww.joule-electra.com%2Fimages%2FIm000392.jpg&hash=4e84cbd8e0dcd94314278ca1057ba5d6)
2 - 6DJ8's
Weight 40 lbs. each
Height - 9 inches
Depth - 18 inches
