Χρήστος Ακρατόπουλος
The DLA-HRM1U is the world's first reference monitor that utilizes JVC's renowned D-ILA™ technology. It reproduces highly accurate representations of a wide variety of signals making it suitable for HD Post Production, HD surveillance operations, animation suites and high resolution computer workstations.
* 48-inch diagonal Reference Monitor
* Native 1920 x 1080 resolution
* Contrast ratio more than 3000:1
* 30 inches deep
* HQV processing by Teranex
* INPUTS:
o Digital: HD-SDI/SDI/DVI/HDMI
o Analog: Component/S-video/Composite/VGA
* Signal formats: 1080P23.98sF, 1080P24, 1080P25, 1080P30, 1080i50, 1080i60, 720P, 480P, 480i, VGA up to 1920x1200, MAC
* HDCP compliant
* LAN connectivity
* Rec 709 color space
Image Device
3 Chip D-ILA® (0.82 inch)
Resolution
1920x1080
Light Source
250 W NSH lamp, 2000 Hrs. lifetime
Brightness
170 cd/m2 (50 ft. L, adjustable option)
Contrast Ratio
3000:1
Color Gamma
Rec. 709
Gamma
4-12 bit tables, 3 preset and 1 user defined
Input-Digital
Dual link HD-SDI (SMPTE 372)
HD-SDI (SMPTE 292), SDI, DVI, HDMI
Scalar Processing / decoder
HQV powered by Teranex
Input-Analog
Component, S-Video, Composite
Input rates-Video
1080P24sF, 1080P24, 1080P60, 1080i, 720P,
480P, 480i, 1080P50, 1080P25, 575P, 575i
NTSC, PAL
Input rates-Computer
QXGA*, WUXGA*, UXGA*, 1920x1080, SXGA+,
SXGA, XGA, SVGA, VGA, MAC
Control
LAN, RS-232, IR, USB 2.0
Options
3D LUT (17 node), Calibration tool, Lamp Brightness control
