Kiss 700 dvd player με υποστήριξη AVC/H.264
Χρήστος Ακρατόπουλος
"One had already expected it of the DP-600-Serie, but starting from the DP-700 KiSS will only supply a DVD Player, which controls also MPEG-4 AVC (H.264). In addition the manufacturer probably sets 8622 with the DP-700 on the sigma Design chip.
With MPEG-4 AVC (Advanced video Coding), also as INTERNATIONAL telecommunication union t H.264, is the compression of videos admits about 50 per cent to be more efficient than with MPEG-4 ASP and/or whereupon based codec such as DivX and XviD. In the ideal case the compression is to be so efficient in the comparison with current procedures up to four times.
The KiSS DP-700 was to be seen on the IFA 2005 at the KiSS and at the Nero conditions, since the equipment supports also the new video codec Nero which is based on MPEG-4 AVC digitally AVC. Nero digitally AVC was developed by the French codec specialist Ateme in co-operation with Nero. Nero recruits with the fact that the new Nero digital Inkarnation exceeds not only the own predecessor, but also competitive codecs of the AVC arena clearly.
KiSS customers are to get a 30-Tage-Testversion von Nero Recode among other things with the purchase of the DP-700 provided, in order to be able to provide their own Nero digital AVC files simply. The current Recode version is still based on a MPEG-4-ASP-Codec with AAC Audiokompression.
The Ethernet able DVD Player KiSS DP-700 will come according to KiSS Technology in the first quarter 2006 on the market. Before - more exactly said in October 2005 - the DP-600 comes on the market. Like the DP-700 he understands himself on DivX and WMV9 also in high resolutions, only on MPEG-4 AVC must thereby be done without."
Βέβαια δεν έχει κυκλοφορήσει ακόμα η σειρά 600 οπότε...
Καλά, ας το βγάλουνε πρώτα πριν το 2007 και μετα το συζητάμε.......
Εδώ το DP-600 ακόμα το παιδεύουν.....(για να μην πούμε για τα υπόλοιπα της σειράς 6xx)......
Απαράδεκτοι.....
yannissails
