Klipsch Cynergy 5.1 Home Theater System
KSF-10.5
KSF 10.5
Sensitivity: 95 dB @ 1 watt/1 meter
Bandwidth: 36 Hz-20 kHz±3 dB
Nominal Impedance: 8 ohms
Crossover Frequency: 2.2 kHz
Power Handling: 100 watts maximum continuous (400
watts peak)
Enclosure Type: Bass reflex via wide flare, rear-firing port
Drive Components: Two-way system using one 1"
(2.54 cm) K-97-KV compression driver with a 90ºx 60º
Tractrix Horn and two 8" 20.32 cm) K-1063-KV
magnetically shielded woofers
Weight: 55 lbs. (25 kg)
Height: 38" (96.52 cm)
Width: 10.25" (26.03 cm)
Depth: 12.5" (31.75 cm)
Finish: Black Ash
KSF-C5
KSF-C5
Sensitivity: 96 dB @ 1 watt/1 meter
Bandwidth: 63 Hz-20 kHz±3 dB
watts peak)
Enclosure Type: Bass reflex via dual rear-firing ports
(2.54 cm) K-96-KV neodymium magnet compression
driver with a 90ºx 60º Tractrix Horn and two 6.5"
(16.5 cm) K-1053-SV magnetically shielded woofers
Weight: 16 lbs. (7.3kg)
Height: 7.875" (20 cm)
Width: 23.9" (9.4 cm)
Depth: 7.3" (18.4 cm)
Finish: Black matte vinyl
KSF-S5
KSF-S5
Sensitivity: 93 dB @ 1 watt/1 meter (equivalent sound energy)
Bandwidth: 60 Hz-20 kHz±3 dB
Crossover Frequency: 1800 Hz
watts peak)
Enclosure Type: Sealed enclosure
Drive Components: Two way system using two 1" (2.54 cm)
K-99-S neodymium magnet compression dirvers with a 90ºx
60º Tractrix Horn and one 6.5" (16.5 cm) K-1018-S woofer
Weight: 13 lbs. (5.9 kg)
Height: 8" (20.3 cm)
Width: 18.25" (46.4 cm)
Depth: 7.3" (18.5 cm)
Finish: Black
Mounting: Threaded insert and double keyhole
KSW-200
KSW-200
Type: 12" bass reflex, tuned port enclosure
Amplifier: 200 watts continuous into 4 ohms
Auto Power On: 2 second ON delay, 15 minute OFF delay
Dynamic Headroom: 1 dB (250 watts into 4 ohms)
Frequency Response: 29-120 Hz±3 dB
Maximum Output: 108 dB
Audio/Video Switch: +3 dB over entire frequency range
Low Pass Crossover: Continuously variable from 40-120 Hz,
24 dB/octave slope above 120 Hz.
High Pass Crossover: Main speakers: line level outputs with switchable
high pass between 40 and 80 Hz, 6 dB/octave slope above
120 Hz. Speaker level outputs with fixed high pass at 100 Hz,
6 dB/octave slope.
Phase: Switchable 0-180 degrees
Inputs/Outputs: Line level RCA phono jacks. Dedicated LFE
channel input. High level speaker terminals.
Drive Component: K-1050-K 12" (30.5 cm) driver
Weight: 69 lbs. (31.3 kg)
Height: 18.75" (47.63 cm)
Width: 17.5" (44.5 cm)
Depth: 17.5" (44.5 cm)
Cabinet: Medium density fiber board construction (MDF)
Finish: Matte finish black vinyl
Voltage: 110/120 VAC 60 Hz – Dual Voltage Export Version
230/120 VAC 50/60 Hz
MADE IN USA
Προκειται για το προσωπικο μου συστημα, που ομως, παρ ολες τις φιλοτιμες προσπαθειες να ξαναφιαξω την υπογα home cinema, καποιοι νεαροι κυριοι δε με αφηνουν.
Ετσι ειναι συσκευασμενα ( τα κουτια τα πεταξα περσυ ) σε πλαστικο με τις φυσσαλιδες.
Η τιμη του συστηματος ειναι 2.000 ευρω.
Μπορω να το δωσω τμηματικα, αλλα μονο αν μαζευτητε και τα παρετε με τη μια.
Αναλυτικα οι τιμες ειναι :
KSF 10.5 : 700 ( ζευγος )
KSF-C5 : 300
KSF-S5 :
400 ( ζευγος )
KSW-200 : 600
Τηλεφωνο στο μαγαζι...
opanamas
