Πωλούνται τα ηχεία βάσης Klipsch RP 160M σε
χρώμα Ebony
άριστη κατάσταση και σε μοναδική τιμή!
300 ΕΥΡΩ!!!
χρώμα Ebony
300 ΕΥΡΩ!!!
Frequency Response: | 45-25kHz +/- 3dB |
SENSITIVITY: | 96dB @ 2.83V / 1m |
POWER HANDLING (CONT/PEAK): | 100W/400W |
NOMINAL IMPEDANCE: | 8 Ohms Compatible |
HIGH FREQUENCY DRIVER: | 1" Titanium LTS Tweeter with Hybrid Cross-Section Tractrix Horn |
Low Frequency Driver: | 6.5" Cerametallic Cone Woofer |
CROSSOVER FREQUENCY: | 1500Hz |
ENCLOSURE MATERIAL: | MDF |
ENCLOSURE TYPE: | Bass Reflex via rear-firing Tractrix port |
INPUTS: | Dual binding posts/bi-wire/bi-amp |
HEIGHT: | 16.67" (42.4 cm) |
WIDTH: | 8.81" (22.4 cm) |
DEPTH: | 12.86" (32.7 cm) |
WEIGHT: | 19.9 lb (9.03 kg) |
FINISHES: | Ebony, Cherry |
Built From: | 2015 |
170,2 KB Προβολές: 0
