Klipsch RS-25 Surround Speaker
Πωλούνται, 200 ευρώ, άριστα (ελάχιστα χρησιμοποιημένα)
Τηλ. 6981109380
Very high sensitivity and power handling
WDST design for superior surround envelopment and effect localization I Dual Tractrix Horn titanium dome compression driver tweeters
Cerametallic cone woofer with low-resonance cast-polymer frame
Back-panel keyhole and threaded insert for wall or ceiling mounting
SPECIFICATIONS
BANDWIDTH 79Hz-20kHz ± 3dB
SENSITIVITY 96dB @ 2.83 volts/1 meter*
IMPEDANCE 8 ohms compatible
CROSSOVER FREQUENCY 2100Hz
POWER HANDLING ENCLOSURE TYPE 75 watts (300 watts peak)
DRIVE COMPONENTS
Bass-reflex via side-firing port
Two-way system using two 1" (2.5cm) titanium dome compression drivers with 4" (10.2cm) square 90° x 60° Tractrix Horns and one 5.25" (13.3cm) Cerametallic cone woofer
WEIGHT8 lbs. (3.6kg)
HEIGHT6.6" (16.8 cm)
WIDTH13.5" (34.3cm)
DEPTH6.75" (17.2cm)
Emmanouel graecorum
