KLIPSCH RS 25 SURROUND
frequency response 79Hz-20kHz ±3dB
power handling 75 w max continuous (300 w peak)
sensitivity 96dB @ 2.83 volts/1 meter (equivalent sound energy)
nominal impedance 8 ohms compatible
crossover frequency 2100Hz
tweeter Two K-132-AN 1" (2.54cm) Titanium dome compression drivers
high frequency horn 2 x 4" square 90°x60° Tractrix® Horns
woofer K-1130-A 5.25" (13.34cm) Cerametallic® cone / cast polymer frame
enclosure material MDF
enclosure type Bass reflex via side-firing port
input connections One set of binding post speaker terminals
dimensions 6.6" (16.8cm) x 13.5" (34.3cm) x 6.75" (17.2cm
ΚΑΙΝΟΥΡΓΙΑ 2 ΗΜΕΡΩΝ!!! ΑΛΛΑΓΗ ΓΙΑ ΜΕΓΑΛΥΤΕΡΑ 400 ΕΥΡΩ
OCAMI
