Lansche No.8, με νέο plasma tweeter
Κώστας Φ.
Lansche Audio, manufacturer of the massless Corona plasma tweeter, will debut their new loudspeaker No.8 at T.H.E. SHOW 2008, St. Tropex, room 2201, featuring a new updated Corona plasma tweeter, four passive 8-inch mid-woofers and four active 12-inch subwoofers all in a sealed cabinet.
"Each subwoofer has its own internal 300-watt analog power amplifier. The mid-woofers use paper composite cones and a moving mass of 8 grams each. The subwoofers have Nomex-Kevlar-Glassfibre composite cones. The Corona plasma tweeter crossover is at 2.5kHz and mid-woofers at 80Hz. Network components are from Duelund and Mundorf. Frequency response is 20Hz to 150kHz. Sensitivity is 99dB/W/m and impedance 8 ohms.The cabinet is finished with matched real wood veneers and several layers of polyester clear lacquer. Dimensions are H1580 x W440 (tapered 353) x D600mm, weight is 120kg each.
6moons.com
gvts
