LAPTOP - Desktop Replacement
•CPU : AMD AthlonTM 64 X2 Processor FX-60
•Display : 17.1" WXGA (1680 x 1050) TFT
•Video Controller : nVIDIA GeForceTM Go  7900 GTX High performance  graphic chip
                                256MB DDRIII Video RAM on board
                                256-bit video memory interface
                                PCI-Express x16
                                Fully DirectX 9.0 support
                                Modular Design
                                H.264 encode support (HD-DVD/BD-DVD playback)
•Memory :  2 GB (2 x 1024 DDR 400)
•Hard Disk : 160 GB ( 2 x 80 5400 rpm RAID )
•Drive : DVD±RW
•Sound System : AC'97 2.2 Compliant Interface
                            3D stereo enhanced sound system
                            Virtual 8-channel audio output
                            Sound-Blaster PROTM compatible
                            S/PDIF Digital output
                            SRS (Sound Retrieval System® ) / WOW 3D sound technology
                            1x Built-in Microphone
                            4x Built-in Speakers
                            1x Built-in Sub woofer
                            1x Built-in Audio DJ Console for music CD (MP3 format compatible)
•I/O Ports : 4x USB 2.0 ports
                    2x Mini IEEE1394a ports
                    1x S-Video jack for TV output (HDTV support)
                    1x Serial port
                    1x Parallel port (LPT1), supporting ECP/EPP
                    1x Infrared Transfer port
                    1x DVI port
                    1x PS/2 port
                    1x Headphone jack
                    1x Microphone jack
                    1x S/PDIF output jack
                    1x Line-in jack for Audio input
                    1x RJ-45 port for LAN
                    1x RJ-11 port for Modem
                    1x DC-In jack
•Dimension : 397(W) x 298(D) x 49.5(H)mm, 15.6"(W) x 11.7"(D) x 1.9"(H)
                        5.8Kg with 12 cells Lithium-lion battery
•Communication : Infrared Transfer : 115.2Kbps SIR/4Mbps FIR, IrDA 1.1 compliant
                                  10/100/1000BASE-T Fast Ethernet onboard
                                  Integrated V.90/56K Azalia Modem (V.92 compliant)
                                  802.11b/g MiniPCI Wireless LAN Module
                                  BluetoothTM Class II V2.0 Module, combo with 802.11b/g Wireless LAN
                                         1.3M-pixel Video Camera module
•Slot : Built-in 10-in-1 Card Reader (MS/MS Pro/SD/MMC/CF/SM/Micro Drive/MS DUO/Mini SD/RSMMC)
          1x Type II PCMCIA socket
   - ΕΓΓΥΗΣΗ : 8 ΜΗΝΕΣ ΑΚΟΜΑ – ΕΧΕΙ ΔΟΥΛΕΨΕΙ ΤΟ ΠΟΛΥ 50 ΩΡΕΣ (ΤΙΜΗ ΑΓΟΡΑΣ 3.500)
   - TIMH  : 2.900
georgetsiakalakis
