Legend Tikandi Speakers με επεξεργαστη
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
  • Tikandi Speakers
  • Design: 3-way Sealed Enclosure
  • Drivers: One 1" Dome Tweeter, One 5.25" Midrange, Two 10" Woofers
  • MFR: 20 Hz - 25 kHz ± 2 dB
  • Sensitivity:88 dB/W @ 1m
  • Nominal Impedance: 6 Ohms
  • Recommended Power: 50 - 200 Watts
  • Marantz MM8003 Power Amplifier Supplied as Part of Package (8 x 140 Watts RMS)
  • Dimensions: 38" H x 12" W x 12" D
  • Weight: 100 Pounds/each
  • DEQX HDP-3 Processor
  • DEQX-HD™ active crossovers; 48dB/octave to 300dB/octave linear-phase
  • Traditional Active 3-way Crossovers from 6dB/octave to 48dB/octave
  • 32-bit, Floating-point, 240-MFLOPS Processing with Dual SHARC DSPs
  • Analogue Volume Control Maintains Full DAC Resolution at Low Listening Levels
  • Analog Inputs: Unbalanced (2 x RCA) and Balanced (2 x XLR)
  • Digital Inputs: S/PDIF (1 x RCA) and AES/EBU (1 x XLR)
  • Microphone input has 48V phantom power for DEQX Calibrated™ mics
  • Outputs: 6 RCA Unbalanced
  • Anodized Black brushed or Silver brushed Aluminum Front
  • Dimensions: 3.5" H x 17" W x 11.5" D
  • MSRP for Tikandi Loudspeaker System as Tested, Including Amp, Processor and All Cables: $19,199
  • MSRP for HDP3 processor with Standard Calibration Kit and Active Balanced Output Module $6,150
  • http://www.legendspeakers.com.au/index.html
The Legend Tikandis with the DEQX HDP-3 are a very special combination. I have never heard better sound in my listening room. The tonal accuracy, frequency extension, and most impressively the ability to pull detail out of recordings was nothing short of astonishing.
http://www.hometheaterhifi.com/two-...peaker-system-with-deqx-hdp-3-processing.html
wendigo
