Lyngdorf Audio MP-60
ενδιαφερον....και το ιδο λενε και στο hcfr
If you’re looking for an alternative in a similar price bracket, the obvious choice is the Trinnov Audio Altitude16. It’s slightly cheaper at £13,000, but offers a nearly identical set of features, with 15.1 channels of processing and support for Dolby Atmos, DTS:X Pro and Auro-3D. It’s attractively designed, well made, and has similar selection of connections.
What really separates the two processors is their room correction systems. The Altitude16 uses Trinnov’s proprietary Optimiser, which evolved out of the company’s professional heritage. As such it’s incredibly sophisticated and flexible, but should really be setup by a suitably trained dealer. You need to know what you’re doing to get the best out of the Trinnov, although anyone who enjoys tweaking will have a field day.
However, in terms of the end result I still felt RoomPerfect resulted in a superior overall experience. The bass was that bit tighter, the soundstage more balanced, and the overall presentation seamless in its cohesion and steering. This was based on memory rather than a side-by-side comparison, but while the Trinnov Altitude16 remains an exceptional AV processor, the Lyngdorf MP-60 is my personal preference.
και παμε και στο HCFR
.......νομιζω οτι ειναι ο μονος που δεν χρειαζεται να ασχοληθεις !!!!
πατας το κουμπακι τα φτιαχνει και απολαμβανεις ;)
...με κοστος βεβαια κοντα στα 15.000 e
Εάν δεν χρειάζεται να ασχοληθείς και δεν δουλεύει καλύτερα στο χειροκίνητο όπως όλοι οι άλλοι (ακόμα κ ο τρινοβ ) τότε χαλάλι εαν μπορεις να τον αγοράσεις
απο τα λιγα που διαβασα ειδα οτι.......
......το RoomPerfect δεν θελει χωρους με βαρυ room treatment
θα το κοιταξω γιατι ειναι ενδιαφερον, μιας και για τα σαλονατα setup δεν εχουν καθολου room treatment ;) :biggrin:
............ετσι εξηγειται η διαφορετικοτητα του ;)
το οτι σε χωρους με room treatment αρκετο δεν απεδωσε ικανοποιητικα !!!!!
One of the world’s most sophisticated solutions for adapting the sound system to the environment
Most high-end products are developed in sonically-ideal listening rooms with optimized dimensions and acoustic treatments. However, in reality, sound systems are installed in authentic living spaces, not sound labs. Your sound system should be perfect in your environment—and we can promise it will be. RoomPerfect™, developed by Peter Lyngdorf, is the end product of more than two decades of pioneering audio research and development. It is an intelligent system, which not only identifies the characteristics of the sound of your speakers but also requires specific measurements of your room acoustics. It then applies corrections to the signal over a twenty-minute process that leaves you with sound that’s perfectly adapted for the shape, size, and acoustic properties of your room.
Στο σαλόνι μου, πάντως, το RoomPerfect είχε κάνει θαύματα.
φανταζομαι οτι θα ειναι αρκετα βελτιωμενο το τελευταιο RP ε ?
......ειναι του 08 ετσι δεν ειναι ?
Το δικό μου είναι του 2012. Η Lyngdorf δεν κάνει συχνά ανανεώσεις στο RoomPerfect. Αν μου πεις ποια έκδοση έχει ο processor του thread θα μπορώ να σου τη διαφορά στις εκδόσεις.
    Safety Last * tl;dr *
Triumph
