M-Audio Fast Track Ultra
xfader
Άλλο ένα μοντέλο από την M-Audio για τη σειρά Fast Trak.
[FONT=Verdana, Arial]The Fast Track® Ultra 8 x 8 audio/MIDI interface takes M-Audio’s acclaimed mobile recording line to the next level with high-speed USB 2.0 connectivity, MX Core™ DSP mixer and four preamps with award-winning Octane™ technology. Featuring both analog and digital I/O, it allows recording on all eight channels simultaneously with pristine 24-bit/96kHz fidelity—while M-Audio’s mature low-latency drivers ensure rock-solid stability and performance. The on-board MX Core™ DSP mixer processes eight hardware inputs and eight software returns to the eight hardware outputs, delivering flexible routing and monitoring with delay and reverb. Compatible with most major audio software, Fast Track Ultra lets you record the way you want—in the studio or on the go.[/FONT]
[FONT=Verdana, Arial]Technical specifications
24-bit/96kHz professional audio on all I/O simultaneously
high-speed USB 2.0 interface
MX Core™ DSP technology
* digital effects processing with assignable parameters
* flexible channel routing options
* expands DSP mixing interface to 16 x 8
4 preamps with award-winning M-Audio Octane™ technology
* 4 XLR microphone inputs—including 2 XLR/TRS combo jacks for mic or instrument level inputs
* 20dB pad on each preamp
* signal/peak LED indicator lights
* phantom power
6 balanced line inputs
6 balanced analog outputs
2 analog inserts
S/PDIF digital I/O
built-in 1 x 1 MIDI interface
2 independent headphone outputs with individual volume controls
USB bus power*
full ASIO 2.0, WDM, MME, and Core Audio support
compatible with most major audio production software
[/FONT]
DAMBO
