M-Audio SBX10 subwoofer
xfader
Για την "ενίσχυση" των χαμηλών συχνοτήτων των studio monitors.
Περιλαμβάνει πετάλι on/off για τη σύγκριση της μίξης με/χωρίς το sub.
The M-Audio® SBX10 active subwoofer is designed to give your monitoring system some serious low end. The SBX10 delivers tight, clean bass response down to 20Hz—revealing the extreme low frequencies in your music so you can make accurate mixing decisions. Comprising a 10" fiberglass/paper composite driver, a 240-watt all-discrete internal amplifier, and a variable 50-200Hz crossover, the SBX10 subwoofer delivers unbeatable performance in a compact chassis—great for studios where space is tight. An oversized magnet, high-temperature voice coil, high-density cabinet and a full complement of inputs are just some of the additional components that round out this high-quality design. The unit even includes a bypass footswitch so you can easily judge how mixes will sound with and without a dedicated subwoofer. The SBX10 represents the perfect addition to any studio monitor setup.
Technical specifications
-10 fiberglass/paper composite cone driver with oversized magnet and high-temperature 2 long-throw voice coil
-240-watt Class A/B amplifier with all-discrete transistor design
flared rear bass-reflex port
-variable 50-200Hz crossover
-20-200Hz low frequency response
-adjustable gain (-30dB to +6dB)
-balanced/unbalanced XLR, balanced/unbalanced 1/4 TRS and RCA inputs
-balanced/unbalanced XLR and balanced/unbalanced 1/4 TRS -outputs allow easy setup of 2.1 monitoring systems
-includes subwoofer bypass footswitch
-phase switch (0/180)
-over-temperature protection
-vinyl-covered high-density internally braced 3/4 MDF cabinet with 1 front and back baffles
-removable grill
-removable feet
Τιμή: 300€
Link κατασκευαστή
xkaragi
