magnat pa 212 400 wrms
πωλουνται σε αριστη κατασταση 2 μηνων 490 ευρω
Configuration 2 way, bass reflex
Impedance 4-8Ohms
Bestückung 2x 12" (30 cm) Tief-Mitteltöner,
1.5" Druckkammer Hochtonhorn
Power handling RMS / max. 400 / 1000 Watt(s)
Dimensions (W x L x D) 385 x 1005 x 390 mm
Frequency response 26-22.000 Hz
Crossover frequency 2.800 Hz
Cabinet surface black carpetProfessionell PA speaker
Stable 19mm MDF cabinet, rugged protection edges and resonance-free metal grill
1.5? (38mm) compression horntweeter
Longthrow woofer-midrange with reinforced papercone and high power magnetsystem
Highly efficent crossover
Extra stable and low resonant carry handles
Speaker terminal with screwterminal and 6.3mm plug
Airflow optimized bassreflex ports
http://www.magnat.de/index.php?id=2375&L=1
6948373320
Alkimos
