πωλείται ο παραπάνω κορυφαιος προενισχυτής σε κατασταση βιτρίνας, δεκτός κάθε έλεγχος! Αθήνα χέρι-χέρι ή αποστολή και επαρχία κατόπιν συνεννόησης. Τιμή 1800 ευρω
Product highlights:
Processing:
Product highlights:
Processing:
- Dolby® and DTS® surround sound decoding
- Dolby Atmos® and DTS:X™ for more enveloping home theater sound
- supports 5.1.2, 5.1.4, 7.1.2 , and 7.1.4 Atmos setups
- DTS Virtual:X simulates height effects without height speakers
- Auro-3D® built-in for three-dimensional soundfields
- IMAX Enhanced certification for improved performance with IMAX Enhanced content (via future firmware update)
- video upscaling (up to 4K) for analog and HDMI sources
- Audyssey MultEQ® XT32 speaker calibration and system optimization includes:
- MultEQ® XT32 advanced auto setup and room calibration uses high-resolution digital processing filters to deliver balanced, dynamic sound to as many as 8 listening positions (expandable to 32 with a professional installer)
- Audyssey Dynamic Volume mode to keep listening levels steady
- Audyssey Dynamic EQ for fuller sound at lower listening levels
- Sub EQ HT provides individual calibration for dual subwoofers, for even bass response throughout the room
- Low Frequency Containment reduces the amount of bass that bleeds into other rooms
- Audyssey MultEQ Editor app for further audio customization (paid app; not included)
- built-in Wi-Fi for listening to music from a networked PC, free internet radio, and music services
- built-in HEOS technology wirelessly connects compatible HEOS components for whole home audio
- includes support for Pandora®, SiriusXM, and Spotify® (subscription required for some
- free HEOS app offers easy Wi-Fi control, settings adjustments, and music selection and playback
- works with Amazon Alexa-compatible voice control assistants
- Apple AirPlay 2 lets you stream directly from an iPhone® or iPad® and ask Siri to play Apple Music (available firmware update)
- supports multi-room audio with compatible wireless speakers
- built-in Bluetooth for wireless music listening with smartphones, tablets, and compatible computers
- plays high-resolution digital music files via USB storage device or a networked computer (PCM
- M-DAX2 (Marantz Dynamic Audio eXpander) for better sound from MP3s and other digital music files
- three-room/three-source output
- line-level outputs for Zones 2 and 3
- All Zone Stereo mode ensures that both zones stay in sync when playing the same source
- Zone 2 HDMI output for watching video content from different sources in two rooms simultaneously
- component and composite video outputs can be assigned to Zone 2
- supports 2nd and 3rd zone output from digital audio sources
- 11.2-channel balanced XLR outputs include outputs for 2 powered subwoofers
- 11.2-channel unbalanced RCA outputs include outputs for 2 powered subwoofers
- HDMI audio/video switching: 8 in (includes 1 front-panel input), 3 out
- HDCP 2.2 technology on all inputs and outputs ensures compatibility with 4K Ultra HD sources and TVs
- HDR-compatible for extended picture contrast and brightness with compatible 4K TVs and HDR-encoded content
- supports HDR10, Dolby Vision™, and HLG
- component video switching: 3 in, 1 out
- composite video switching: 4 in, 2 out (includes front-panel input)
- digital audio inputs: 2 optical and 2 coaxial
- 6 analog stereo audio inputs (including front-panel input)
- MM phono input for connecting a turntable
- 7.1-channel preamp inputs
- Ethernet port for wired network connection
- front-panel USB port for audio playback from USB flash drives
- RS-232C, IR, remote, and 12-volt trigger connections for use with external controllers
- 1/4" headphone output
- high-quality 32-bit DACs on all channels
- Marantz's Hyper Dynamic Amplifier Module (HDAM) offers improved dynamic range and detail while reducing noise
- current feedback circuit for accurate, natural sound at all volume levels
- Pure Direct mode turns off unused circuitry for cleaner audio signals
- 4K/60p and 3D video pass-through
- Setup Assistant guides you through the initial connection process and settings
- intuitive, full-color on-screen guide
- Video Select lets you listen to music while watching video from a different source
- HDMI standby pass-through allows HDMI switching without powering up receiver
- AM/FM tuner
- remote control
- detachable power cord
- 17-3/8"W x 7-5/16"H x 16-15/16"D
- weight: 22.9 lbs.
- warranty: 3 years
- 60-day returns
- MFR # AV7705
- Item # 642AV7705
