Τιμή : Περίπου 400 ευρώThe new Marantz DV6600 is a high-performance multi format DVD player that incorporates advanced digital technologies for extraordinary picture quality, and improves upon the DV6500 by the addition of an HDMI digital video and audio output and upscaling to 1080i resolution.
The DV6600 is optimised for true, high-end audiophile performance, for music and movies. Virtually any 12cm disc can be played back including DVD-A, DVD-V, DVD-R/RW, SACD, CD-R/RW discs. It also handles compressed audio discs containing MP3, DivX or WMA files.
This innovative DVD player will excite you for years to come
Specification Marantz DV6600
Features
High quality playback of DVD-V, DVD-A, SACD, SVCD, CD, DivX, WMA, MP3, DVD-R/RW, DVD+R/RW enables ultimate disc compatibility
PAL/NTSC progressive scan offers improved picture resolution and eliminates virtually all motion artifacts
High definition video scaling creates a perfect match with any high resolution video display device up to 1080i
PAL progressive scan offers improved picture resolution and eliminates virtually all motion artifacts
216MHz/11-bit video DAC offers real life high grade component video performance
192kHz/24-bit DAC offers faithful and accurate high quality performance for multi-channel playback
Audio EX mode for the best audio performance
Built-in DD and DTS decoders to enjoy the audio excellence of the DV6600 regardless of the format played
Full bass management for all audio formats to customize and optimize the sound of your speaker system
Cursor leaf control on front panel enables convenient and easy menu control even without the remote at hand
Connections
Component Video outputs:1
S-Video outputs: 1
Composite Video outputs: 1
SCART (RGB) outputs: 1
Digital video/audio: HDMI
Analogue audio outputs: 1
Digital Optical audio ouputs: 1
Digital Co-axial audio outputs: 1
5.1 decoded channel output
General
Remote control: RC6600 DV
Weight 2.2kg
Available in silver or black
Dimensions W x D x H mm 440 x 211 x 75
