Marantz SA-7S1 - H ναυαρχίδα της σειράς Reference
Κώστας Φ.
H Marantz δείχνει τα δόντια της στις Esoteric, EMM Labs κλπ.... :happy_2:
"This is the flagship of the Marantz Reference series. Constructed around a custom-made aluminum transport mechanism, the SA-7S1 features a new DAC chipset from NPC (Nippon Precision Circuits), which is said to have the best performance specifications of any currently-in-production DAC chipset. It is asserted that this new chipset gives the SA-7S1 the highest signal-to-noise ratios, dynamic range and lowest Total Harmonic Distortion (THD) specifications amongst competitive machines.
The new HDAM-SA2 analog stage features a toroidal power supply, with separate supplies for the digital sections, analog section and the display.
Features:
  • Custom Designed Aluminum Transport
  • New NPC DAC Chipset
  • HDAM-SA2 Current Feedback Output
  • Low Jitter with Internal Clock
  • Phase Conversion in Digital Domain
  • Audiophile-Grade Selected Components
  • Plays SACD-Stereo, CD, CD-R/RW
  • Current Feedback Circuitry
  • High-Speed Analog Circuit with HDAM® SA2
  • Newly Designed Aluminum Transport
  • Digital Isolator for D/A Grounding Separation
  • Marantz Original PEC (Phase Error Compensation) PEC777F2
  • High Accuracy NPC SM5866A5 D/A Converter
  • External Clock Input
  • Phase Inversion for Balanced Output
  • Toroidal power transformer w/Copper Shield Case
  • All Copper Plated Chassis w/ Double Layer Bottom
Normally, I find extremely detailed equipment to be fatiguing and often less than emotionally nourishing. Not the case here. The SA-7 has the lowest level of listening fatigue of any SACD machine I have personally reviewed, even in comparison with the Lindemann, which has been my historical champion in this regard. Resolution is as good or better than the Meitner, my reference for that attribute.
Conclusion
Even after a few short weeks, it is hard for me to imagine being without the SA-7. I think this lovely lady may be "the one."
I also want to audition her little sister, the SA-11 …which retails for about $2k less than the SA-7.
$6500 is a lot of money …but compared to the machines I view as competitive (dCS, Lindemann, Meitner, Esoteric, etc.) the SA-7 is not only a better all over package, but a screaming deal.
Right now I am driving my VMPS-30s with the newly acquired Ming Da EL-34-AB (preview to come shortly) …and the combination of this shockingly good $1200 integrated amplifier from China, and the Marantz SA-7S1 has me grinning from ear to ear.
If you are even remotely considering an SACD player, you must, repeat MUST give the SA-7 and presumably the SA-11 a serious listen. I think you will be amazed with what you hear!"
Περισσότερα: positive-feedback.com
Specifications:
Sampling Frequency: 2.8224 MHz 1 bit DSD (SACD)/ 44.1 kHz 16 bit linear PCM (CD)
Dynamic Range: 114dB (SACD, Filter 3), 100dB or more (CD, Filter 1)
Frequency response: 2Hz - 100kHz (SACD), 2Hz - 20kHz (CD)
Total Harmonic Distortion: 0.0009% (SACD, Filter 3), 0.002% (CD, Filter 1)
Power Consumption: 26 watts
Dimensions: 18" Wide x 5.35" Tall x 16 ¾" Deep
Weight: 49 lbs
Κώστας Φ.
Απάντηση: Marantz SA-7S1 - H ναυαρχίδα της σειράς Reference
Αν και το χρυσαφί δεν πάει με τα υπόλοιπα μηχανήματά μου, θα έκανα μία εξαίρεση! :mrgreen:
Οι σειρά SA της Marantz είναι πραγματικά φανταστική. Αν όντως το SA-7S1 παίζει, όπως λένε, τόσο καλύτερα από το SA-11S1, τότε οι ανταγωνίστριες εταιρίες που ανέφερες παραπάνω θα ταρακουνηθούν για τα καλά.
Όπως και να το κάνουμε, οι τεχνολογίες και οι όποιες καινοτομίες στα ψηφιακά μέσα αναπαραγωγής... είναι Ιαπωνική υπόθεση.
Κώστας Φ.
Mήπως να κυνηγήσουμε μία συνάντηση/ακρόαση πηγών με highlight το Marantz? Ίσως απο Σεπτέμβριο...
Αν περιλαμβάνεται και PC-based ψηφιακό frontend στο "πανηγύρι", ακόμα καλύτερα!
Για εμένα ο Σεπτέμβριος θα είναι λίγο πιεσμένος μήνας λόγω επαγγελματικών υποχρεώσεων και λόγο... μετακόμισης. Όμως, από τα μέσα Οκτωβρίου και έπειτα, θα είμαι μέσα σε ότι και αν κανονιστεί. Αν θέλεις, μπορούμε να το οργανώσουμε και στον καινούριο μου χώρο ακρόασης, ο οποίος έχει επιμεληθεί σε διαστάσεις και σε ένα σορό άλλους τομείς για τέτοιες καταστάσεις.
Κώστας Φ.
Απάντηση: Re: Marantz SA-7S1 - H ναυαρχίδα της σειράς Reference
...μπορούμε να το οργανώσουμε και στον καινούριο μου χώρο ακρόασης, ο οποίος έχει επιμεληθεί σε διαστάσεις και σε ένα σορό άλλους τομείς για τέτοιες καταστάσεις.
Νικόλα, ακούγεται ενδιαφέρον το project του νέου χώρου ακρόασης και νομίζω επιβάλλεται το χειμώνα να τον τιμήσουμε δεόντως! :bravo:
Εν τω μεταξύ, όταν έχεις χρόνο, άνοιξε κανένα thread με φωτογραφίες των εργασιών ετοιμασίας του χώρου κλπ. Η δημιουργία ενός dedicated χώρου ενδιαφέρει πολλούς - έστω και για να δουν τι χάνουν! :cool_4:
Μόλις γυρίσω Αθήνα, θα ανεβάσω μερικές φωτογραφίες από τις μέχρι τώρα εργασίες. Το σημαντικότερο που έχει γίνει μέχρι στιγμής, όπου δεν θα φανεί στις φωτογραφίες, είναι ότι οι τοίχοι έχουν χτιστεί στις ακριβείς αποστάσεις, ανάλογα με το ύψος που έχει το ταβάνι, σύμφωνα με τον τύπο που υπολογίζει τις ιδανικές διαστάσεις για την καλύτερη εξάλειψη των στάσιμων κυμάτων.
Φυσικά, δεν έχει δοθεί βάση μόνο σε αυτό. Έχουν επιμεληθεί καταλλήλως και πολλά άλλα, όπως π.χ. το υλικό του πατώματος, τα αποσβεστικά, το κεντρικό καλώδιο παροχής κλπ. κλπ. Θα προσπαθήσω να πείσω τον ειδικό που με βοήθησε και με βοηθάει σε αυτές τις εργασίες, να μπει να γράψει μερικά πράγματα.
Κώστας Φ.
:respect: :cool_4:
.... ανάλογα με το ύψος που έχει το ταβάνι, σύμφωνα με τον τύπο που υπολογίζει τις ιδανικές διαστάσεις για την καλύτερη εξάλειψη των στάσιμων κυμάτων.
Να μαντεψω ?
Υψος = 2.40 μ ??
Οποτε ...
Πλατος = 4.00 μ
Μηκος = 6.40 μ
:happy_4:
Είσαι του Cardas βλέπω Μιχάλη (1 προς 1,66 προς 2,66)
Υπάρχουν όμως και άλλες αναλογίες σωστές όπως:
1. Αναλογίες Sepmeyer: 1.00:1.28:1.54 ή 1.00:1.60:1.33
2. Aναλογίες Louden: 1.00:1.40:1.90
3. Αναλογίες Βoner: 1.00:1.26:1.59
Re: Απάντηση: Marantz SA-7S1 - H ναυαρχίδα της σειράς Reference
Δεν τον ξερω τον Καρνταση.
Εγω ξερω τον λεγομενο απο πολλους "Χρυσο Κανονα" :
0.6 / 1 / 1.6
:cool_4:
Κώστας Φ.
:cool_4:
Δείτε κι αυτά τα post του Βασίλη, από παλαιότερη συζήτηση: Click 1 και Click 2
:cool_4:
Ενα - Ειδον
Δυο - Ειδον
Αυτο που λεω ειναι πολυ κοντα στην προταση της ΙEC.
Να μαντεψω ?
Υψος = 2.40 μ ??
Οποτε ...
Πλατος = 4.00 μ
Μηκος = 6.40 μ
:happy_4:
Έπεσες πολύ κοντά Μιχάλη. :cool_4: Οι ακριβείς διαστάσεις θα βγουν αφού ολοκληρωθούν οι εργασίες στο πάτωμα και με τα υλικά στο ταβάνι, έτσι ώστε να έχουμε το ακριβές ύψος. Μόλις τελειώσει αυτό, θα περαστούν τα κατάλληλα υλικά στους πλαϊνούς τοίχους έτσι ώστε να φτάσουμε τις ακριβείς αποστάσεις που ορίζει ο τύπος για το πλάτος. Όσον αφορά το πίσω τοίχο, εκεί δεν υπάρχει κανένα πρόβλημα, αφού εξ' αρχής έχει μήκος 9 μέτρα και όπως καταλαβαίνεις θα χτιστεί ένας άλλος τοίχος κάπου εκεί κοντά στα 6,40 (όπως έγραψες και εσύ) και θα ολοκληρωθεί ο χώρος.
Πάντως, μέχρι στιγμής έχουμε πέσει μέσα στους αρχικούς υπολογισμούς και οι αποστάσει του "ύψους" με τις αποστάσεις του "πλάτους" συμβαδίζουν απόλυτα, κατά την διάρκεια των εργασιών (μονώσεις, σοβατίσματα κλπ.). Σε αυτές τις δουλειές, δεν φτάνει μόνο ένας καλός sound engineer. Χρειάζονται και μερακλήδες εργάτες, σοβατζήδες και πατωματζήδες.
Κώστας Φ.
Άλλο ένα review, αυτή τη φορά απο το Hi-Fi Choice (δημοσιευμένο και στο tech.co.uk)...
For
  • Not just state of the art, but also remarkably easy on the ear
  • The finest player we have heard in a long while
  • Makes high-class disc replay sound almost too easy
Against
  • Costs an arm and a leg
Verdict
Stunning player aimed at the serious audiophile community, that offers remarkably transparent sound in the very specific sense that it is virtually impossible to hear it working. CD replay often approaches the quality of SACD.
"It's a remarkable tour de force and we're being cautious when we pronounce this as arguably the finest player available. It's also far from expensive for a machine with such ambitions.
If you want a disc player that will do the very finest musical job possible with your CDs and SACDs - the only really serious remaining audio disc formats - the Marantz SA-7S1 can even be considered a bargain at £5,000!"
Full Review: tech.co.uk
n_olympios
Μαντιναδόρος!
Του χαλκού το κάγκελο γίνεται στο εσωτερικό...
Για να δούμε...
Χάλκινο σασί - check
Τοροειδής μετασχηματιστής - check
Ταιριασμένοι πυκνωτές - check
Και η έκδοση KIS τι θα έχει τότε? :crazy_1:"happy_1"
Κώστας Φ.
Full Review για το Marantz απο το Positive-Feedback (το αρχικό άρθρο του thread ήταν "unofficial" εντυπώσεις απο άλλο συντάκτη). O άρρωστος το στέλνει για mods... :crazy_1:
"Under the hood are two very interesting new features:
  1. It is the first commercial product to use the latest DACs from NPC, alleged to have the best measured specs of any DAC currently made. This is appealing because my last two CD/SACD players (both modified Sonys) used the same Burr-Brown DAC chipset, and this time I wanted to try something different.
  2. It has a brand new deluxe transport mechanism, designed to compete with Esoteric's VRDS- NEO. No typical flimsy, jittery, off-the-shelf, cheap plastic drive for this puppy. It's shocking, but many very high-end manufacturers use the same cheap OEM drive/laser/transport as any budget CD or DVD player you can get at Best Buy.
The analog section is op-amp free as you'd expect at this price point, and uses Marantz's proprietary "HDAM" modules instead. The "problem" is that these modules are complex, containing many parts, with several of them stacked one after the other in the analog stages of all of their better gear, allegedly having a negative effect on their overall transparency. As a result, one often read descriptions of Marantz gear incorporating these HDAMs as being warm, analog, pleasant, relaxing, and musical. All well and good, but you'll notice "neutral", "resolving", and "dynamic" are not among those adjectives. As you'll see, to some extent my impressions of the player agree with those stereotypes of Marantz's "house sound".
Features
The SA-7S1 has a number of cool (or maddening, depending on your point of view) features that are worth exploring.
It has an Invert Phase button, which obviously enough inverts the phase of the CD/SACD you are playing. As it turns out, many CDs and SACDs are actually (and amazingly) out of phase. From what I've read, when an out-of-phase CD is corrected, the sound seems to snap into better focus, and sounds more coherent. I've played around with this one a little bit, and so far, I've either been unable to tell the difference, or have noticed a subtle worsening of the sound. Thus, I surmise I haven't yet used it on a bona fide out-of-phase CD, but I'll keep trying.
Dr. Sardonicus responds …Here, I must disagree. My experience with switching polarity on discs that "don't sound right" has been significant. I am annoyed it cannot be done from the remote, but the function is very useful.
Then there are the 3 special filters that change the way the SA-7S1 crunches the numbers and have subtle effects on the sound and frequency response. In general, the changes are minor and frustrating. You can get lost and end up spending days endlessly A/B-ing the action of the different filters trying to decide which one is microscopically preferable to you.
In addition to these 3 filters, the Marantz has two other sets of parameters that can be manipulated. There is a Noise Shaper button, which adds or subtracts digital feedback in the DAC, and a DC Filter button whose purpose is not adequately described by the manual.
Dr. Sardonicus …as I understand it, the DC filter is to address recordings with significant amounts of non-musical low frequency energy (essentially a rumble filter).
So you can see there are almost exponentially complex numbers of different combinations of filters and functions that can be turned on and off. It's either audiophile heaven or hell, depending on your personality. (Hopefully, I won't get so worked up I toss the thing out the window.)
Final Thoughts
The Marantz SA-7S1 is definitely not one of those polarizing, love it or hate it pieces. In fact, it's so well-judged, and so well-voiced, you would have to go well out of your way to actively dislike it. It aims to please, and on those terms, it truly succeeds. But as you've been reading some of my impressions, I know there's one major question they probably beg for you—is the Marantz (go ahead, say it) boring? Has it been overcooked and over-thought to the point of blandness, or conversely, has it been dumbed-down to the lowest common denominator guaranteed not to offend anyone?
I really don't think so. Yes, it's inviting and subtle, refined and composed, and could never be called "forward" or "aggressive". But that doesn't mean it's limp, thin, lifeless, or un-involving—quite the contrary in fact, it's completely captivating. However, if you're looking for a source that will fill in some hole or other in your system, this ain't it. It's almost perfectly even-handed in every regard; to ask for "more" of this or that from it is really to demand (gasp!) some added coloration.
Me, I'm not afraid to ask for a little "more" zest and spice from the Marantz, and that's why I'm sending it off to the Mod Man to be upgraded. When I packed it up and sent it out, here's exactly what I asked him to address in order of importance:
1. Improve dynamics, heft, slam, power, punch, oomph, etc.
2. Increase transparency, palpability, and address blackness of background. It has a very low-level (but noticeable) amount of "fog" between you and the performers. Images are a tad "soft" around the edges could use some firming up.
3. Tone is a hair on the warm side of neutral, a small correction wouldn't hurt. Tone is also a tad on the dry side, and if that's fixable, that would be great.
And that's it. In every other way, the Marantz SA-7S1 exceeds the performance of my current reference. In stock form, it's a real winner, and will make most folks very happy indeed. Still, based on previous experience, I expect that the mods will enhance a lot more than those 3 simple bullet points, improving virtually all areas of performance, even those the SA-7S1 already does so much better than anything else I've heard. I've owned 3 modified players so far and am a big believer in the power of these upgrades, so as you can imagine, I'm really anticipating the return of this already superb player. If Positive Feedback will have me back, I'll happily follow up this report with my impressions of the fully modified SA-7S1. Cheers!"
-- Mark Lawton
Click for more
    Safety Last * tl;dr *
Tsarou
