Marantz SR4001
πωλειται Marantz SR4001 120 ευρο
Product Specification:
General
Product Type
AV receiver
Width
17.3 in
Depth
15.1 in
Height
6.3 in
Weight
25.1 lbs
Audio System
Sound Output Mode
7.1 channel surround
Built-in Decoders
Dolby Pro Logic, DTS-ES decoder, Dolby Pro Logic II, Dolby Digital Surround EX, DTS-ES Matrix 6.1, DTS-ES Discrete 6.1, DTS 96/24, Dolby Digital, DTS decoder, Dolby Pro Logic IIx
Audio D/A Converter
24bit / 192kHz
Surround Sound Effects
Circle Surround, SRS TruSurround
Digital Sound Processor (DSP)
Yes
Surround System Class
7.1 channel
Signal-To-Noise Ratio
105 dB
Input Impedance
47 kOhm
Input Sensitivity
168 mV
Amplifier Output Details
80 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% ( surround ) ¦ 105 Watt - 6 Ohm - 20 - 20000 Hz - THD 0.08% ( surround )
Built-in Clock
Sleep timer
Built-in Display
Fluorescent
Additional Features
On-screen display, gold plated connectors, HDCD decoder
Response Bandwidth
8 - 100000 Hz
Timer
Sleep
Connectors
Headphone Jack
Yes
Coaxial Digital Input
Yes
Optical Digital Input
Yes
Optical Digital Output
Yes
Coaxial Digital Output
Yes
Radio
Type
Radio tuner - AM/FM - digital
Tuner Frequency Range
FM: 87.5 - 108 MHz, AM: 531 - 1602 kHz
Tuning Display
Fluorescent display
Preset Station Qty
50 preset stations
Antenna Form Factor
Loop AM / wire FM
Total Harmonic Distortion
Mono: 0.2%, stereo: 0.3%
75 dB
Supported RDS Functions
PTY, PS
Remote Control
Type
Universal remote control - infrared
Features
Learning
Connections
Connector Type
1 x headphones ( phone stereo 6.3 mm ) - front ¦ 1 x composite video/audio input ( RCA phono x 3 ) - front ¦ 1 x S-Video input ( 4 pin mini-DIN ) - front ¦ 1 x SPDIF input ( TOSLINK ) - front ¦ 4 x composite video input ( RCA phono ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 4 x S-Video input ( 4 pin mini-DIN ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x monitor output ( RCA phono ) - rear ¦ 1 x monitor output ( 4 pin mini-DIN ) - rear ¦ 1 x monitor output ( RCA phono x 3 ) - rear ¦ 3 x component video input ( RCA phono x 3 ) - rear ¦ 1 x 7.1 channel audio line-in ( RCA phono x 8 ) - rear ¦ 7 x audio line-in ( RCA phono x 2 ) - rear ¦ 3 x audio line-out ( RCA phono x 2 ) - rear ¦ 2 x SPDIF input ( RCA phono ) - rear ¦ 2 x SPDIF input ( TOSLINK ) - rear ¦ 1 x SPDIF output ( RCA phono ) - rear ¦ 1 x SPDIF output ( TOSLINK ) - rear ¦ 1 x 7.1 channel audio line-out ( RCA phono x 8 ) - rear ¦ 2 x HDMI input ( 19 pin HDMI Type A ) - rear ¦ 1 x HDMI output ( 19 pin HDMI Type A ) - rear ¦ 7 x speakers output ( screw-type ) - rear ¦ 2 x remote control - rear ¦ 1 x AM antenna - rear ¦ 1 x FM antenna - rear
Miscellaneous
Included Accessories
AM antenna, FM antenna
Power
Power Device
Power supply - internal
Voltage Required
AC 230 V ( 50/60 Hz )
Power Consumption Operational
500 Watt
Power Outlets
1 AC outlet
και φωτο απο το δικο μου
Uploaded with ImageShack.us
Απάντηση: Marantz SR4001
Σταυρο χαρηκα για την γνωριμια,καλοακουστος ο ενισχυτης
Γιωργος
Γιώργο καλησπέρα. Και εγώ χάρηκα και σε ευχαριστώ πολύ. Χθες (μάλλον σήμερα δηλαδή) 12 με 3 ρύθμιζα και όλα είναι μια χαρά.
Καλό καλοκαίρι.
Σταύρος.
ΑποστολοςΒαζ
