Marten design: Miles II loudspeakers
marten design Τα μοντέλα φέρουν ονόματα μεγάλων μουσικών της jazz!
SWEDISH made
TECHNICAL SPECIFICATION
Frequency range: 31-20000 Hz, +- 3 dB
Power rating: 200 W
Sensitivity: 87 dB/w/m
Impedance: 4 ohm (minimum 3.8 ohm)
Type: Ported system, port resonance 32 Hz
Drive units: Two 7” ceramic units, 1.25” ceramic unit
Crossover frequency: 1:st order, 300 & 2200 Hz
Terminals: Biwiring, WBT
Internal wiring: Jorma Design
Box material: 2 x 16 mm:s MDF, glued with deadening glue
Measurements (H x W x D): 108.0 x 23.6 x 43.0 cm
Net weight: 57 kg/ea.
Sort of wood: Cherry
REVIEW:
http://www.positive-feedback.com/Issue17/milesll.htm
Miles II
Retail: $10,000 a pair
TimoleonTimoleon
