These Australian designed amplifiers are high end music audio systems for the new millenium. Our systems combine:
* Elegant styling
* Top quality components
* High quality lacquer
* High level stereo sound
Through years of intensive research and precision production, Melody valve serial amplifiers are certain to be the top brand amplifier worldwide.
Aπό το site της εταιρείας
ΜΕΡΙΚΑ ΠΡΟΪΟΝΤΑ:
Vacuum Tube:845×2,6SN7×2,EL34×2
Power Output: 88W ClassA
Zero-Feedback
Frequency Response: 20Hz~20KHz
Output Impedance: 4Ω,8Ω
Input Sensitivity: 800mV
S/N: 85dB
Total Distortion of Resonant Wave: 1%
AC Power: 220V±5% 50Hz~60Hz
Dimensions(mm): 260(W)×196(H)×485(D)
Weight: 26kg
Vacuum Tube: 300B×2,6SN7×2,6SL7×1
Power Output: 28W
Frequency Response: 20Hz-30KHz
Input Impedance: 100KO
S/N:≥90dB T.H.D:1%
Dimensions(mm): 285(W)×185(H)×275(D)
Weight: 18kg
Vacuum Tube: EL34×4,6SL7×2,6SN7×2、 5AR4×2
Power Output: 40W+40W ClassAB1
Input Impedance: 250KΩ
Input Sensitivity: 380mV
S/N:≥90dB T.H.D: 1%
AC Power: 110V±5% 50Hz~60Hz
Dimensions(mm): 430(W)×185(H)×380(D)
Weight: 28kg
* Elegant styling
ΜΕΡΙΚΑ ΠΡΟΪΟΝΤΑ:
Zero-Feedback
S/N: 85dB
Weight: 26kg
Power Output: 28W
S/N:≥90dB T.H.D:1%
Weight: 18kg
S/N:≥90dB T.H.D: 1%
Weight: 28kg
