Monitor Audio Bronze BR Series
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Μετά την ανανέωση της σειράς silver ήρθε και η σειρά της πιο προσιτής Bronze.
Η νέα σειρά θα ονομάζεται Bronze BR και οι διαφορές με την προηγούμενη, σύμφωνα με τον κατασκευαστή, είναι:
 Up-rated C-CAM tweeter. Higher sensitivity and greater bandwidth. Usable response now to beyond 30 KHz.
 New design bass driver chassis with improve rigidity and increased open area to provide lower reflections.
 All MMP2 bass units now benefiting from greater linearity. Extended pole and motor system adjustments highlighted by our FEA analysis and Fine-motor predictions.
 MMP2 Bass mid-range and bass drivers are now finely tuned and optimised for the specified cabinet air-loads.
 All MMP2 Mid-range drivers now have a pointed metal phase dome adopted from the RS series providing greater voice coil concentric rigidity. On and off axis response has been improved as a result. Dedicated bass drivers have an inverted dust cap.
 Improved magnetic shielding circuit, utilising FEA simulation.
 New terminal panel providing easier access. Up-rated Gold metal body terminal provide a high-end functionality and appearance.
 Improved crossover component quality. Component layout has been carefully considered and designed to avoid induction interference.
 BR5 and BR6 now have dual chambers for the bass and bass-/mid-range drivers to operate in. The results are improved efficiency and mid-range clarity
 Universal Out-rigger feet increase the overall foot-print of the BR5 and BR6 providing greater stability and improved overall appearance.
 BR5 and BR6 now have low down terminal panel positioning to avoid un-necessary cables.
 New COVA pearlescent vinyl finished lift the quality and appearance to another level (Walnut & Cherry). In most cases it is extremely difficult to differentiate these new finishes from real wood. Cova vinyl finishes are extremely high quality and produced in the U.K
 The entire BR range is 100% ROHS compliant
 Characteristic family sound. Typically flat, neutral overall balance.
Τα ηχεία που θα απαρτίζουν την νέα σειρά είναι τα βάσης BRONZE BR1 και BRONZE BR2, τα δαπέδου BRONZE BR5 και BRONZE BR6 το κεντρικό BRONZE BR-LCR, τα περιφερειακά BRONZE BR-FX και τέλος το subwoofer BRW-10 .
Στην αγορά θα κυκλοφορήσουν τέλη Σεπτέμβρη, αρχές Οκτώβρη.
Η σειρά έρχετε σε 2 φινιρίσματα (wallnut και cherry).
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Λογικά πρέπει να έχουν έρθει.
Επικοινώνησε με τον εισαγωγέα (Ηχοέκφραση) για περισσότερες πληροφορίες.
ΗΧΟΕΚΦΡΑΣΗ
Κεντρικό Κατάστημα: Πύργου 1 & Πρωτόπαππα Ηλιούπολη Τηλ. 210 9953001 - 210 9956130
Υποκατάστημα: Ηλία Ηλιού 58 & Φραντζή Τηλ. 210 9010575
Καλή μάρκα, με σπουδαία απόδοση για την τιμή τους. Μήπως πρέπει να ενδιαφερθεί κάποιος να εισαγάγει και τα Paradigm (hint, hint για τον πολιότριχα :lol: Α.Κ.), που είναι παρόμοια ως προς τον λόγο απόδοσης/τιμής? 8)
RDoherty said:
Από ποιόν?
Είχε και περίπτερο στην έκθεση. Και δωμάτιο για "σοβαρή" ακρόαση.
Που κοιτούσες; :p
(Ξέρω, ξέρω...όπου και εγώ! :wink: :lol: )
tyler durden
Μη ριβγιούερ
ta Monitor Audio B2 της προηγουμενης σειρας παντως, ηταν πολυ μουσικα ηχεια με πολυ γλυκο ηχοχρωμα, ,με μονο μειωνεκτημα οτι εχαναν τα καλα τους στοιχεια σε λιγο υψηλοτερες σταθμες.
Πολυ τιμια εταιρια
nikpapageo
