R90
Radius 90 is a radical departure from most satellite speakers inasmuch as it doesn't look radical. It's a high-class mini monitor, only smaller. In stark contrast to the hard, cold metal appearance of most A/V speaker packages, it has the same sumptuous real wood veneer and lacquer finishes that grace Monitor Audio's reference speakers. The same engineering standards and attention to detail, too, right down to the radiussed corners of the cabinet and high-quality, gold-plated cable terminals.
It may be the smallest speaker Monitor Audio has ever made, but it is also one of the most remarkable. Its clarity, dynamics and imaging abilities have to be heard to be believed. It can fill a room with high fidelity sound yet, visually, melt into the background.
It was with this in mind that Monitor Audio designed the high quality die-cast metal wall bracket supplied with each speaker. This has a very shallow profile and holds the Radius 90 close to the wall, but its wide range of movement allows it to be easily directed towards the listening area.
Each Radius 90, whether finished with real wood veneer or Video silver lacquer, is supplied with black and silver grilles to customise both the speaker's appearance and its match with your room's decor.
Features
Unique drivers designed and tooled for Radius. The new cast bass-mid chassis is made from high-tech glass loaded engineering polymer that provides better damping than metal and increased overall strength.
MMP 2. Monitor Audio's second generation metal matrix polymer cone material now uses a high-pressure injection moulding process to achieve different thickness at desired points of the cone geometry for greater stiffness and consistency resulting in superior
25mm Gold CCAM tweeter extends to 25kHz
Magnetically shielded drivers allow Radius to be safely used near sensitive microprocessor equipment or video displays
High quality crossover uses high grade metalised Polypropylene capacitors for increased clarity. High-grade air core and laminated iron core inductors give lowest possible distortion and low insertion losses.
Specially developed high grade PCOFC internal cable is used throughout to ensure maximum signal transfer at all frequencies and low signal resistance.
Single through-bolt driver fixing provides mechanical de-coupling and enhanced mid-band clarity and resolution. The through-bolts also act as rigid cross bracing to give a very solid non-resonant cabinet.
Rear ported design with rigid MDF construction throughout.
Smooth radius edges reduce diffraction effects for better imaging
Video silver lacquer and real wood veneer finishes.
Perforated metal grilles supplied in both black and silver to match individual decor or taste.
Specially designed die-cast metal wall bracket system (supplied) provides 20 degrees of vertical and horizontal pivoting for easy positioning.
![](/forum/proxy.php?image=http%3A%2F%2Fwww.monitoraudio.co.uk%2Fimg%2Fradius%2Fr90.gif&hash=160a926cc10bf89ef2f15bae92a26edd)
Features
