The Musical Technology C-1 LINE CONTROL UNIT is actually two completely independent monoaural preamplifiers, to achieve absolute channel separation. It consists of two separate components: the audio circuitry chassis and the DC power supply chassis. Transformers, filament supply circuits and the pre- regulated plate supplies are housed in a separate chassis to eliminate hum fields from the audio circuits. No Transistor or Fet is used in the audio circuit.
C2 TUBE LINE CONTROL UNIT
The Musical Technology C-2 Line Control Unit is actually TWO completely independent MONOAURAL PREAMPLIFIERS, to achieve absolute channel separation. The result is a more precise imaging, a better and enhanced soundstage.
No Transistor or Fet is used in the audio circuit. Wide bandwidth, high intrinsic linearity, low distortion and low output impedance
MUSICAL TECHNOLOGY PHONO UNIT P1
Specifications
Frequency response according to the RIAA standard within ± 0,5 dB
Maximum output voltage >8 V at all frequencies.
Gain variable from 33 to 54 dB at 1Khz
Dimensions (cm) 14.5(w) x 6.5(h) x 22(d)
VARIABLE GAIN, IMPEDANCE, CAPACITY
VERY HIGH SENSIBILITY (0.1mV)
EXCEPTIONAL DYNAMICS
NO OVERALL FEEDBAK
NO INTEGRATED CIRCUITS
OVERSIZED AND SEPARATED POWER SUPPLY
FT POWER AMPLIFIER
SPECIFICATIONS
MT FT 200 MK2 Hybrid, High Bias, Power Amplifier
Nominal Power: 200 + 200 W 8 Ohm, 340 + 340 W 4 Ohm
20 + 20 W 8 Ohm CLASS A
Bandwith: 2 - 150 Khz,
Input Sensibility and Impedance 1,5 V 100 KOhm
Ratio S/N: > 90 dB
Distortion (THD): < 0,1%
Driver: 2 ECC88 tubes per channel
Output: 10 Mosfets per channel
Power Supply: 2 x 600 VA toroid transformers + 2 x 30 VA toroid transformers
120,000 microF capacitance
Damping Factor: > 50
Dimensions: 460 (w) x 220 (h) x 350 (d) mm
Weight: 35 Kg
