ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
NeuNeo High Definition DVD player incorporates the latest video technologies such as world's first pixel based de-interlace engine and amazing 1280 X 1024 VGA output resolution. The player has a high-end scaler and delivers astonishing high definition video from regular DVD title. The color, depth and detail are well defined with minimal artifacts. It is the best companion ( video source ) for HDTVs, big screen projectors and any high definition display device.
Support 1080i, 720P, 576P and 480P output, VGA output support 640x480, 800x600, 1024x768 and 1280x1024.
Upscale DVD playback to high definition (1080i via component, 1280x1024 via VGA). Perfect companion for high resolution projector, big screen HDTV and computer monitor.
Built-in high end level scaler delivers astonishing high definition image.
System contains one 32bit Risc CPU, one 24bit video processing CPU and one 24 bit RISC audio processing CPU. Total power equal to 1Ghz Pentium CPU.
Fast 16bit 149Mhz Video DAC and 192 kHz 24 Bit Audio DAC ( 32 bit/133Mhz Audio DSP).
HDCP is not required for playing copyright DVD title in high definition mode.
Brushed stainless steel front panel.
Fastforward / back forward (up to 40X) and ZOOM ( up to 8X)
Easy use full color navigation system.
Fully compatible w DVD/SVCD/VCD/CD/HDCD/MP3/WMA/Photo-CD/CD-R/CD-RW/DVD+R/DVD-R/DVD+RW/DVD-RW.
Built-in Dolby and DTS decoder.
Progressive scan, PAL/NTSC TV system compatible, support 4:3 & 16:9 TV mode.
Smart update function ( firmware upgradeable ).
Component, S-Video, VGA and Composite video output.
Optical, Coaxial S/PDIF and RCA output. Support Dolby 5.1 and DTS digital output or 2 Channels analog stereo output. Built-in Dolby 5.1 / DTS decoder, 5.1 channel output.
Ultra slim and stylish design. Dimension: 17 x 10.5 x 1.7 inch (430 x 270 x 43 mm).
Package includes 1 DVD Player, 1 Remote Control, 1 pair analog Video /Audio Cable and User manual. Power 100 ~ 240 AC/50 ~ 60Hz
ΜΟΛΙΣ 199$....
