Nokia Mediamaster 9600s common interface+IRDETO II CAM
Nokia Mediamaster 9600s common interface+remote control original+IRDETO II CAM
Demodulator QPSK,1-45 MS/s
Video decoder MPEG-2 Main Profile@Main Level
Data rates up to 15 Mbits/s
Video formats 4:3 and 16:9
Audio decoder MPEG-2 layer I & II (Musicam)
Processor Motorola 68340, 16 MHz
RAM 1 Mbyte (2 Mbytes Extension)
Flash memory
Display 720x576 pixels
IF range 950-2150 MHz με DVB2000 SOFTWARE
IRDETO II CAM για δορυφορικους δεκτες με common interface---ΚΑΙ ΓΙΑ NOVA με freecam 019 software
100 €
Νικος 6972 811405
kyta thn epoxh poy kykloforhse o dekths den yphrxan tetoia moter.
sthn selida ths nokia leei gia yposthrixh disceq gia lnbs opote logika 8a doulebei kai to moter.den mporw omws na sou pw me sigouria.ayto brhka sth selida ths nokia
IMPORTANT!
If you have a combination which consists of more than 1
LNB and/or more than one dish, you must connect the
LNB:s to an external switch. Once installed and configured,
the switch automatically performs the choice of correct
LNB to the desired programme channel.
This external switch is better known as a DiSEqCTM switch
(Level 1 or 2 type). The DiSEqC switch can be located close
to the LNBs, which then means you only need one cable
down to the Mediamaster.
The following description will explain how to install the
switch.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Tελικά κατέβασα το manual από το site τησ Nokia και λέει ότι δεν υποστηρίζει...
Δυστυχώς δεν μου ταιριάζει...
DAMBO
