Nova Audio
Nova Audio, Inc. is a high-end and professional loudspeaker manufacturer based in Texas. Founded in 1992, Nova began producing OEM loudspeaker systems for the international market. These products are well known for their exceptional performance and value. In 1995, a new line of loudspeakers from Nova was introduced at the Winter Consumer Electronic Show (WCES). Our flagship Evolution is a no-holds-barred design that stands six feet tall and weighs in at 600 pounds per channel. Using some of the recent technologies and the finest materials available, these loudspeakers are engineered to deliver superior performance and most importantly, remarkable musicality. Nova products can be found in some of the world's finest home and studio sound systems.
Evolution II
SPECIFICATIONS
Type: 3-way vented design
HF Driver: 1" soft dome tweeter
Dual rear chamber pressure release
MF Driver: Two 7" Carbon-Fiber composite mid-woofers
LF Driver: Two 10" High-output specially coated subwoofers
Bandwidth: 18Hz to 20kHz (± 3dB)
Sensitivity: 88 dB (1 watt @ 1 meter)
Impedance: 4 ohms nominal (3 ohms minimum)
Input Power: 100 watts minimum
Connection: 2 pairs of Heavy Duty binding posts
(Bi-wire/Bi-amp)
Finish: Exotic Rosewood (Matching pair)
Removable Grill Covers
Dimensions: 72" H x 16" W x 35" D
Weight (system): Approx. 1200 lbs (system)
1550 lbs. crated
$39,000 USD per pair
Applause
SPECIFICATIONS
Type: 2-way vented design
LF Driver: Two 7" Carbon-Fiber composite woofers
Bandwidth: 30Hz to 20kHz (± 3dB)
Sensitivity: 89 dB (1 watt @ 1 meter)
Input Power: 30 watts minimum
Connection: Two pairs of 5-way binding posts
(Bi-wire/Bi-amp)
Finish: Black, Light Oak,
Natural Cherry, or Sapeli
(Finished on front, back, top, & sides)
Dimensions: 48 1/4" H x 9 1/2" W x 14 1/4" D
Weight: 85 lbs. each (100 lbs. shipping)
From $5,500 USD per pair
SPECIFICATIONS
Stand-Mounted
LF Driver: 7" Carbon-Fiber composite woofer
Bandwidth: 45Hz to 20kHz (± 3dB)
Impedance: 8 ohms nominal (6 ohms minimum)
Input Power: 15 watts minimum
Connection: 5-way binding posts
Finish: Black, Natural Cherry, or Sapeli
(Finished on all 6 sides)
Dimensions: 16" H x 9 ½" W x 10 ½" D
Weight: 26 lbs. each
(57 lbs. per pair shipping)
From $2,300 USD per pair
desmios2025
