Onda Ligera Reflector 218Q
m1ts0s
News poster
Acoustic design : Open type active acoustic system
There is analog and digital input.
The loudspeaker enclosure cabinet is designed and patented by "Onda Ligera". The cabinet has no reflective surfaces. The system can be mounted in the room with no sound degradation whatsoever. The system tales up very little space due to its "airy" construction. Angular characteristics are identical in all directions and they all have point radiation.
The loudspeakers can be additionally supplied together with analog amplifiers.
SPECIFICATIONS
- Woofers 4 х 18",
- Tweeters 1.4",
- Frequency range 20-20000 Hz,
- SPL: 127dB
- Low-frequency section, sensitivity 100 dB,
- High frequency section sensitivity вч 110 dB,
- D-class amplifier,
- Low frequency section: 700 Watt,
- High-frequency section: 100 Watt,
- Overall dimensions: 850x850x350
- System Weight per channel 55kg
https://berlin-hifi.de/ONLINESHOP/L...::2994.html?MODsid=58t7e1tvtmli42daotpoomd792
https://www.fidelity-magazin.de/2016/09/07/test-onda-ligera-reflector-218q-aktivlautsprecher/
gperdik
