Onkyo TX-SR707 AV Receiver Boxed
Σε άριστη λειτουργική και εμφανισιακη κατάσταση χωρίς το παραμικρό πρόβλημα ή σημάδι,στο κουτί με όλα τα χαρτιά του , remote, καλώδιο ρεύματος σφραγισμένο, κεραία αχρησιμοποίητη και μικρόφωνο Audussey σαν καινούργιο.Χρηση μόνο σε home cinema μαζί με τελικό.
100 watts x 7 into 8 ohms (20-20,000 Hz) at 0.08% THD
THX Select2 Plus certification
THX listening modes for optimize surround sound at any listening level
Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, DTS-HD High Resolution Audio, THX Surround EX®, Dolby Digital EX, DTS-ES™, Pro Logic® IIx, Pro Logic® IIz, and DTS Neo:6 decoding
SIRIUS satellite radio capable (requires SIRIUS subscription and optional SiriusConnect™ home tuner kit)
iPod®/iPhone® integration (requires optional DS-A3 or UP-A1 iPod dock)
HD Radio ready (requires optional Onkyo UP-HT1 HD Radio tuner)
Audyssey Laboratories' MultEQ six-point auto setup and room calibration system (microphone included)
Audyssey Dynamic EQ™ for fuller sound at lower listening levels
Audyssey Dynamic Volume™ mode to keep listening levels steady
dual-room/dual-source audio (powered and line-level stereo audio output for 2nd room; using powered 2nd-room output allows 5.1 home theater in main room)
RIHD (Remote Interactive over HDMI) control via HDMI with compatible components (HDMI-CEC)
back surround speaker channels re-assignable for bi-amping front left and right speakers
192kHz/24-bit digital-to-analog converters for all channels
Direct/Pure Audio modes for better stereo sound
high-current amplifier design
learning/multibrand remote
17-3/16"W x 6-13/16"H x 15-13/16"D
Connections:
1080p-compatible HDMI switching: 6 in, 1 out (including 1 front-panel input)
1080p video upconversion with Faroudja DCDi Cinema Enhancement for all non-HD sources (upconverted video available through HDMI output only)
HDMI version 1.3a with support for Deep Color, x.v.Color, auto lip-sync, DVD-Audio, SACD, and HDMI-CEC
component video switching (2 in, 1 out)
digital inputs: 3 optical (including 1 front panel), 3 coaxial
5 audio/video inputs, including:
1 front-panel input with composite and S-video
4 rear-panel inputs with composite and S-video
3 audio-only inputs (including phono)
7.1-channel analog audio preamp output
RS-232 port for automated control systems
1 pair of main speaker outputs
Τιμή:280€ IMG_20230107_132020.jpg IMG_20230107_131549.jpg IMG_20230107_131541.jpg IMG_20230107_132034.jpg IMG_20230107_130658.jpg
xkaragi
