ONKYO TXDS 797 THX-TECHNICS SL 1200MK2
ΠΩΛΟΥΝΤΑΙ ΚΑΙ ΤΑ ΔΥΟ ΜΑΖΙ Η ΚΑΙ ΞΕΧΩΡΙΣΤΑ.ΕΙΝΑΙ ΚΑΙ ΤΑ ΔΥΟ ΕΛΑΧΙΣΤΑ ΧΡΗΣΙΜΟΠΟΙΗΜΕΝΑ.ΤΟ ΠΙΚΑΠ ΦΟΡΑΕΙ ΚΑΙΝΟΥΡΙΑ STANTON ΚΕΦΑΛΗ ΚΑΙ ΒΕΛΟΝΑ ΚΑΙ ΤΟ ΠΟΛΥ ΝΑ ΕΧΕΙ ΠΑΙΞΕΙ 20 ΔΙΣΚΟΥΣ.Ο ΕΝΙΣΧΗΤΗΣ ΕΧΕΙ ΠΑΙΞΕΙ ΠΕΡΙΠΟΥ 100 ΩΡΕΣ ΣΥΝΟΛΙΚΑ ΚΑΙ ΕΙΝΑΙ Ο HIGH END THΣ ONKYO ΣΕ ΑΣΗΜΙ ΧΡΩΜΑ.ΟΛΑ ΜΑΖΙ 650 ΕΥΡΩ.ΤΗΛ 6978339463.
up
Onkyo TX-DS797 6.1 Channels Receiver
Consumer Rating:
Manufacturer: Onkyo - See Site
The new TX-DS797 offers you a major breakthrough-the ability to turn your house into a digital multimedia dream-without draining your... More
The new TX-DS797 offers you a major breakthrough-the ability to turn your house into a digital multimedia dream-without draining your savings account. Not only is it equipped with enough inputs and outputs for the most elaborate systems, it has plenty of high-current, ultrawide-bandwidth power to fill even large entertainment rooms, dual-zone operation, 192 kHz/24-bit D/A converters for all 6 main channels to deliver powerful, precise sound, and can handle virtually any multichannel format out there-today and tomorrow-including DVD-Audio and THX Surround EX. But what will impress you the most about the TX-DS797 is the stellar sound performance-it's unmatched by any other receiver in its class. If it weren't for its elaborate video input and output provisions, you could call the TX-DS797 an audiophile's receiver. Audition it for yourself and you won't be satisfied with anything less. Minimize Consumer reviews (2)
See product details
See product accessories
Already own this item? Write a review
Product Details and Features
Key Features
Type Receiver
Number of Channels 6.1 Channels
Stereo Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
Surround Mode Power 100 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
Surround Sound Dolby Digital® • DTS ES® • THX EX® • Dolby Pro Logic II
THX Certification Select
DSP
DSP Modes Enhanced • Mono Movie
Inputs / Outputs
Rear Input Connectors RCA (2 Audio Channels) x 8 • Digital Coaxial x 3 • Digital Optical x 3 • Composite (Video) x 5 • S-Video x 5 • Component x 2
Rear Output Connectors RCA (2 Audio Channels) x 3 • Digital Optical x 1 • Composite (Video) x 3 • S-Video x 3 • Component x 1
Front A/V Connections Composite x 1 • Couple RCA Jack x 1 • Headphones x 1 • Optical x 1 • S-Video x 1
Surround Analog Inputs 7.1 Channels x 1
Preamp Outputs 7.1 Channels
Convenience
Number of Zones 2
Speaker Impedance 4 Ohm • 6 Ohm
Tuner Presets 40 Channels
Tone Controls Bass & Treble
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Illuminated Remote Illuminated
Design Keypad
Dimensions
Width 17.13 in.
Depth 18.06 in.
Height 6.88 in.
Weight 35.9 lb.
Warranty
Warranty 2 Years
Miscellaneous
Included Accessories AM Loop Antenna • Remote Control
Power Consumption 550 Watt
manolomike
