O P3
The Halo P 3 Preamplifier continues our tradition of incredible sound and tremendous value while adding stunning industrial design. With features like direct balanced XLR inputs and outputs, a unique switchable phono/line input stage, and a remote control that also operates the T 3 Tuner, the P 3 will provide you with hours of musical enjoyment. The beautiful looks and amazing sound quality of this two-channel preamp make it suitable for both the first time high performance listener and the seasoned audiophile.
3 Specs:
Frequency response: 5 Hz - 55 kHz, +0/-1 dB, full output
Total harmonic distortion: < 0.01% 1 kHz; < 0.03% 20 kHz
IM distortion: < 0.03%
Maximum output: > 8 V before clipping
Input impedance: line input 30 kW; phono 47 kW
Output impedance: 60 W
Input sensitivity: line inputs 150 mV, +/- 5%; phono 2 mV
Max input level: 10.5 V before clipping
S/N ratio:
line input > 92 dB, A-weighted, ref 1 V output
line input > 84 dB, unweighted, ref 1 V output
phono > 72 dB, ref .5 mV input
Crosstalk: > 55 dB, 20 kHz
Channel level matching: < 0.1 dB
Voltage: Switchable for 110V - 120V or 220V 240V operation
Dimensions: 17-1/4" w x 4-1/8" h x 13-3/4" d, 3-5/8" h without feet
Net weight: 16 lbs.
A23 power Amp
The Halo A 23 Amplifier is the ultimate combination of superior technology, incredible sound, advanced features and stunning industrial design. With high current Class A/AB amplification, smooth sounding MOSFET drivers, and balanced XLR inputs, this amp will bring out the best in your speakers. The A 23 two channel amplifier boasts 125 watts of THX Ultra 2 certified power per channel, and includes an adjustable audio sensitivity trigger as well as a 12v trigger for ease of operation. Whether its movies or music, the A 23s performance will leave you breathless.
23 Specs:
Continuous power output:
125 watts RMS x 2, 20 Hz - 20 kHz, 8W, both channels driven
200 watts RMS x 2, 20 Hz - 20 kHz, 4W, both channels driven
400 watts RMS x 1, 20 Hz - 20 kHz, 8W
Current capacity: 45 amperes peak per channel
Power bandwidth: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion: < 0.06 % at full power
IM distortion: < 0.04 %
Slew rate: >130 V/΅second
Dynamic headroom: > 1.5 dB
Interchannel crosstalk: > 80 dB at 1 kHz; > 63 dB at 20 kHz
Input sensitivity: 1 V for 28.28 V, THX Reference Level
Input impedance: 33 kW
S/N ratio: > 112 dB, input shorted, IHF A-weighted
Damping factor: > 800 at 20 Hz
Voltage: Switchable for 110V 120V or 220V 240V operation
Dimensions: 17-1/4" w x 4-1/8" h x 13-1/4" d, 3-5/8" h without feet
Net weight: 28 lbs.
