Parrot CK3100 Bluetooth Car Kit
With the Parrot CK3100 Bluetooth Car Kit allows you to make and receive calls without getting your hands off the wheel. The CK3100 seamlessly pairs with your Treo 650 or 700W smartphone and gives you superior performance all without wires. It's backlit mountable display shows who's calling, last number dialed and more. It uses the car's audio speakers and automatically mutes the radio during a call. It has an easy to user interface featuring Caller ID, phonebook synchronization, last calls received, and last calls dialed. It is not limited to work only with Treo's in fact it will work with any Bluetooth phone.
To use the Parrot CK3100 Bluetooth Car Kit your car does not need to be Bluetooth compatible.
The CK3100 is available for $ 178.95
arishonda
