PEAVEY SCORPION SP-15825 FULL RANGE 15' (2 TEMAXIA)
Τα θρυλικα μεγάφωνα PEAVEY SCORPION !! 15'
Δεν υπηρχε συναυλια από το 1970-1980 που να μην ηταν η κορυφαια επιλογή ειτε σαν μεγάφωνα κιθαρας ειτε μόνιτορ!!
300 ΕΥΡΩ ΚΑΙ ΤΑ 2!!
THΛ 6983454280
Features
  • 15"
  • Impedance: 8 Ohms
  • Power capacity: 800 W Peak 400 W Program 200 W Continuous
  • Sensitivity: 98.7 dB / 1 W 1 m
  • Usable freq. range: 40 Hz ~ 2 kHz
  • Cone: Kevlar® impregnated cellulose
  • Voice coil diameter: 2.5" / 64 mm
  • Voice coil material: Aluminum ribbon wire Kapton former Nomex® stiffener Solderless diffusion welded OFHC copper leads
  • Net weight lb. / kg: 12.75 lbs. / 5.8 kg
  • Znom (ohms) 8
  • Revc (ohms) 5.54
  • Sd (Square Meters) 0.084
  • BL (T/M) 17.10
  • Fo (Hz) 50.1
  • Vas (liters) 132.4
  • Cms (uM/N) 174.5
  • Mms (gm) 70.30
  • Qms 6.05
  • Qes 0.345
  • Qts 0.326
  • Xmax (mm) 3.1
  • Le (mH) 0.3
  • SPL (1W 1m) 98.7
  • No (%) 4.70%
  • Vd (cu. in. / ml) 13.9 / 227
  • Pmax (Watts pgm.) 400
  • Disp (cu. in. / ml) 201/ 3294
  • Weight Unpacked: 12.76 lb(5.79 kg)
  • Weight Packed: 18.00 lb(8.165 kg)
  • Width Packed: 21.5"(54.61 cm)
  • Height Packed: 22.5"(57.15 cm)
  • Depth Packed: 9.25"(23.495 cm)
Nikos67
