Phonic i7600 EQ
Gojakla
Αρχαιολάγνος πιουριτανίστας
EQ 30 περιοχών, αγορασμένο το 2004, ΕΛΑΧΙΣΤΑ χρησιμοποιημένο, σε άριστη κατάσταση.
Χαρακτηριστικά:
Phonic i7600
dual 30-band digital graphic equalizer features a digital equalizer and a real-time spectrum analyzer (RTA) in a single rack space unit. Phonic i7600 comes loaded with 780 bright LEDs to provide clear and immediate setting displays. i7600 has EQ sections that can be bypassed for quick comparison between the processed and unprocessed sounds. Phonic i7600 Features:
  • Dual-channel 29-band real-time spectrum analyzer (RTA)
  • 24-bit A/D and D/A converters with 256/512 times over sampling for high headroom and resolution
  • Internal 32-bit/44.1 KHz processor
  • Provides 12 dB of boost or cut
  • Channel-link function
  • Stores up to 60 programs: 30 factory-set, 30 user-defined
  • Selectable unit of measurement for RTA line signal: dBu or dBV
  • Six view range options for band-level measurement
  • Six response time options
  • Peak-hold options: permanent and none
  • Three weighting options: A weighting, C weighting, and flat
  • Pink noise generator outputs balanced test signals at 0 dB
  • Bypass function
  • Variable low-pass filter (LPF) and high-pass filter (HPF)
  • Balanced XLR and 1/4" TRS inputs and outputs
  • Operating levels of +4 dBu and -10 dBV independently selectable for input and output
  • 780 bright LED indicators
  • Rack mountable in one rack-space chassis
Τα actual προς πώληση:
Στα €250 :hi:
FotisLam
