Phono Stage GRAHAM SLEE
Πωλείται σέ άψογη κατάσταση τό phono stage σέτ Era Gold καί Elevator τής Graham Slee μέ τά PSU1 εξωτερικάτροφοδοτικά. Ενα από τά καλύτερα phono στή προσιτή κατηγορία τιμών.
Specification
Γιά τό Era :
Nominal Input sensitivity: 4mV rms
Maximum input: 45mV rms
Nominal output: 472mV rms
Maximum output: 5.3V rms
Gain: 41.5dB (120)
Input resistance: 47kOhms
Input capacitance: 100pF
Output will drive: >600Ohms
Noise: -68dB CCIR
Distortion: 0.02%
RIAA accuracy: <0.5dB
Frequency response: 5Hz - 2.7MHz (-3dB)
Channel balance: 0.2dB
Channel separation: 64dB
καί
Specification
Γία τό Elevetor :
Input sensitivity range: 125-750 micro-volts
Gain: 22.5dB
Input resistance: see table below
Input capacitance: 100pf
Equivalent input noise (EIN): -120dB CCIR Q-Pk [-130dB RMS (20Hz-20kHz)]
Distortion: 0.02%
Frequency response: 0 - 900kHz (-3dB)
Dimensions: 165 x 107 x 50mm approx. (excluding controls and connectors)
Weight: 850g approx. (excluding remote power supply)
Τιμή : 750e
giorgos8907
