PIONEER VSA-AX10i-S+PIONEER DV-757Ai
ο ενισχητής ειναι ultra 2 και πάει πακέτο με το dvd με ψηφιακο i link.
2109822928 μετα τις 15:00 έως αργά το βράδυ
KΏΣΤΑΣ....
The very latest incarnation of the ‘AX10' is the new VSA-AX10i-S, featuring Pioneer's revolutionary Advanced Resolution Digital Audio Interface. IEEE1394 - alternatively known as i.LINK or FireWire - is the new industry standard interface for the secure digital transmission of high-resolution audio from DVD-Audio and SACD sources. Pioneer's state-of-the-art universal DVD player features an i.LINK output, while the VSA-AX10i-S now includes a matching i.LINK input for unprecedented fidelity when playing the latest music releases on DVD-Audio and SACD. With sufficient power delivery and transparency to preserve the enormous dynamic range and pure clarity of today's higher resolution digital recordings, the VSA-AX10i-S includes 7.1-channel line inputs and outputs for all requirements. Under the bonnet are 7 channels of power amplification for THX Surround EX and DTS Extended Surround A/V systems. And for high-end 5.1-channel systems the VSA-AX10i-S's seven power amplifiers can be configured for bi-amping a system's main front left and right channels.
At Pioneer we describe it as a ‘multi-channel stereophonic' amplifier. At AIR Studios they call it their ‘monitor reference'. In your home you'll hear your favourite stereo and multi-channel recordings as the professionals heard it at the mixing desk. The VSA-AX10i-S amplifier will be your monitor reference standard.
Specifications
Key features VSA-AX10i-S
Digital-To-Digital Transmision via i.LINK
DTS-ES & DTS 96/24 Decoding
High-End 192kHZ/24-bit D/A Converters
Air Studios Monitor Reference
The Ultimate S/N Ratio for DVD-Audio
Advanced Multi-Channel Stereophonic Philosophy
THX Ultra 2 Certification
Surround Sound Formats VSA-AX10i-S
Dolby Digital Yes
Dolby Digital EX Yes
Dolby Pro Logic Yes
Dolby Pro Logic II Yes
DTS Yes
DTS-ES Matrix 6.1 Yes
DTS Neo: 6 Yes
DTS 96/24 Yes
Surround Modes Advanced Cinema: Action, Musical, Drama, SCI-FI, Monofilm, 5-D/7-D Theater
Advanced Concert: Classical, Chamber, Jazz, Rock, Dance
Power Output VSA-AX10i-S
Rated Power Output 150W +150W (20 - 20kHz, 0.09%, 6 Ohm)
Input (Sensitivity/Imp.): LINE 382 mV / 47 kOhm
Frequency Response: LINE 5 - 100.000 Hz (+0 dB, -3 dB)
Signal-to-Noise Ratio: LINE (DIN) 93/73 dB
Construction VSA-AX10i-S
Symmetrical Power Train Design Yes
Double Layer Chassis Yes
Copper-Plated Chassis Yes
Transformer Stabiliser Yes
3-D Space Frame Yes
Dimensions (W x H x D) 440 x 203 x 476 mm
Amplifier Specifications VSA-AX10i-S
Digital Signal Processor Sharc 32-bit x 2, 48-bit (24-bit double precision)
D/A Converter 192 kHZ/24-Bit
(one for each CH)
A/D Converter 96 kHz/24-Bit (multi-channel + 2-channel))
Input & Output connections VSA-AX10i-S
i.LINK 2
Multi-Channel Input 7.1 ch
Digital Audio Input 8 (assign)
Digital Coaxial Input 3
Digital Optical Input 5 (Front-in incl.)
Digital Audio Output (Optical) 2
Audio/Video Output 2A / 3AV + 2V
Phono Input Yes
Pre-amp Output Yes, All (7.1 ch)
A/V Input on Front Yes
Speaker A/B Versatile speaker configuration
Audio Features VSA-AX10i-S
THX Surround EX Yes
Audio Scaler Yes
Digital Noise Reduction Yes
Midnight Listening Mode Yes
Bass/Treble Tone Controls Yes
Loudness Yes
Video Features VSA-AX10i-S
Video Signal Selector Yes
Universal Video Converter Yes
Input (Sensitivity/Impedance) 1 V p-p / 75 Ohm
Frequency Response Component Video
(720p compatible) 5 Hz - 40MHz (+ 0dB, -3dB)
Remote Control VSA-AX10i-S
Type LCD Touch Panel - Preset & Learning
Multi-Operation (Macro) Yes
Source Control DVD, Satelite Tuner, MCD, DTV
Interface VSA-AX10i-S
Function Rename Yes
Klipschlascala_pro1988
