PORTABLE DVD 7 '' LG DP171
DVD PORTABLEThe DP 171 Portable DivX DVD player has a built-in 7-inch wide Swivel LCD screen, which allows for a high degree of flexibility. This player is really compact, so you could carry it just about any where that you travel.
Besides, the DP 171 Portable DivX DVD player is equipped withy built-in stereo speakers. This player supports a number of formats including VCD, SVCD, WMA, JPEG, Kodak CD, CD-R, RW, DVD R, and DivX formats.
Moreover, the 100x High Speed Smooth Scan, enables the user to view videos and movies with crystal clear resolutions. Moreover, the on-screen Graphics User Interface makes it very simple to operate the LG DP 171 Portable DivX DVD player.
The LG DP 171 Portable DivX DVD player comes bundled with a removable battery pack with a backup of 3 ½ hours, and an in-car charger of DC 12V.
130 EUROS
xkaragi
