PREVIEW: Canton Vento Reference 1 DC
Απάντηση: PREVIEW: Canton Vento Reference 1 DC
ωραιο εργαλειο
ειρωνια η τυχη ? rotel +rotel 1090
Nick Arvanitakis
Audio Pro
Aντιγραφω απο το αμερικανικο http://www.enjoythemusic.com
και χαιρομαι γιατι μια φορα ενα προιον ειναι πολυ ακριβοτερο στην αλλη μερια του Ατλαντικου!
Canton's new Vento Reference 1 DC ($30,000 per pair) is said to be the company's largest, most accurate, and best performing loudspeaker to date. The Canton Vento Reference 1 DC is designed to showcase the company's ability in engineering, modeling, and testing. This 3.5-way floorstanding model stands 56.3 x 15 x 22.2 (HxDxW in inches) and weighs 194 pounds. The cabinet walls are over an inch thick and are constructed from seven layers of fiberboard, pressure laminated one at a time into a sturdy monocoque structure. Internally, the cabinet is separated into four isolated chambers, allowing for optimal matching of internal volume to each individual driver. Driver compliment consists of a pair of 12-inch aluminum cone woofers, two 7-inch aluminum midrange drivers, and a ADT-25 aluminum-manganese tweeter. The Canton Vento Reference 1 DC loudspeaker is available in real wood veneer finishes of cherry or maple, or with a hand rubbed silver piano lacquer finish.
Δεν ξερω ποσο καλα παιζουν με τον ROTEL .Αργα η γρηγορα θα τα παρουσιασουμε στο AVSITE και θα αποκτησουμε δικη μας αποψη!
Ξεχασα να γραψω πως η Λιανικη Τιμη Καταλογου για την Ευρωπη ειναι 15000 ευρω!​
nikpapageo
