Proceed AMP5
σε αριστη κατασταση.Nα υπογραμισω οτι ο ενισχυτης ζυγιζει πανω απο 50 κιλα,κ απο οτι μπορει να δει καποιος διπλασιαζει κ στα 4ΩΗΜ,οποτε καταλαβαινεται τα αποθεματα ισχυος που εχει.Ειναι επισης ΤΗΧ CERTIFIED.Η τιμη του στα 1600 ευρο.
Τεχνικα χαρακτιριστικα:
Rated power output:125 w/ch rms @ 8W, all channels driven,
20 Hz–20 kHz with no more than 0.1% THD
250 w/ch into 4W
n Frequency response: within 0.15 dB from 20 Hz to 20 kHz
n Signal to Noise ratio (main outputs): better than –80 dB (ref. 1 w)
n Input impedance: 100kW (balanced)
10kW (single-ended)
n Voltage gain: 23 dB (balanced)
29 dB (single-ended)
n Input sensitivity: 2.24 V for full rated output (balanced)
1.12 V for full rated output (single-ended)
n Power consumption: less than 150 W in standby
less than 250 W when fully on and at idle
n Mains voltage: determined by the needs of country for which
the unit was manufactured; cannot be reset by dealer or user
n Overall dimensions: See “Dimensions”
n Shipping weight: 119 lbs. (54 kg)
n Connector Complement: two binding posts per channel
one 3-pin XLR balanced input connector per channel
one RCA input connector per channel
two 1⁄8" mini-jacks for remote turn-on and loop-through
two RJ-45 modular connectors for PHAST™ communications
one IEC AC mains connector
n Output impedance: less than 0.05W, 20 Hz – 20 kHz
http://avclub.gr/forum/attachment.php?attachmentid=39354&d=1242296171
Απάντηση: Proceed AMP5
ειμαι νεος χρηστης του φορουμ και τωρα το ειδα. Υπαρχει ακομα? thanx,
opanamas
