Purist Audio Design Aether Rev3
To Purist Audio Design Aether Rev3 ειναι το κορυφαιο καλωδιο ρευματος που κατασκευασε ποτε η Purist Audio βαζοντας ολη τη τεχνογνωσια της, custom σε ελαχιστα κομματια παγκοσμιως. Οι αγωγοι του δεν ειναι μονο χαλκος οπως τα συνηθισμενα (ακομα και τα ακριβοτερα) καλωδια που φαινονται στην ιστοσελιδα της Purist Audio Design εξ ου και η εξωφρενικη αρχικη του τιμη...
Ισως το καλυτερο καλωδιο ρευματος παγκοσμιως.Tο δινω για να χρηματοδοτησω καποιες αλλες αγορες...
Απο κατω υπαρχουν και καποιες πληροφοριες απο τον ιδιο το Jim Aud, ιδιοκτητη της Purist Audio, περιγραφοντας το καλωδιο.
1200 ευρω απο 4000 τιμη καινουργιου
AETHER History
The history behind the AETHER is an interesting one. The AETHER started with a customer request of the ultimate cable, but did not want the RLS Cable System, due to the distraction of the cable glowing, the external power supplies, and fiber optics that are necessary for the RLS Cable System. AETHER was developed using an Enhanced Ferox with advanced metallurgy on the conductors and different material treatment on the cable. With this we were able to obtain an additional noise reduction of 6 Db QUIETING. The sonic results were beyond our wildest dreams, and the listener became a part of the listening experience, losing track of time and space. The cable is build only by Jim or his chief engineer in very limited numbers.
Specifications: AETHER
Type AC cable
Design goal Extreme low resistances, high noise Immunity
Conductor Stranded, multi-gauge alloy
Metals Copper, silver, gold, shibu-ichi
Shielding Foil, Enhanced Ferox
Dielectric Teflon®, Polyvinyl chloride
Dielectric Specific Gravity Teflon® 2.43
Dielectric Tensile Strength, psi Teflon® 2700
Nominal capacitance (PF/m) 223
Dielectric Strength, volts/mil Teflon® 1000
Maximum current rating based IECC & AC plug 20 amps
Maximum current rating based on conductors 30 amps
Gauge (actual) 10 AWG
Break-in time (hours) 125
Cable diameter 1Ό” OD
Material treatment Cryomag©
Απάντηση: Purist Audio Design Aether Rev3
Επειδη πολλοι λιγοι γνωριζουν το καλωδιο, ειναι το πιο εξωτικο καλωδιο ρευματος που εβγαλε η Purist Audio Design, τοσο που δε το ανεφερε καν στην ιστοσελιδα της.... Για οσους αρεσκονται στον ηχο της εταιριας, δε παει πιο πανω....
costasgera
