Raumfeld Stereo M
m1ts0s
News poster
Wi-Fi bookshelf speakers that set a new standard for big, true-to-source sound. A 3-way system produces powerful and balanced playback while an integrated amplifier with 320 watts allows the speakers to reach even higher, distortion-free levels. A bigger enclosure allows the system to produce surprisingly deeper, richer bass. If more is what you want, the Stereo M is where you’ll find it.
  • 2 identical Wi-Fi speakers with a 3-way construction for a wide stereo panorama
  • Integrated 320 watt amplifier and coaxial drivers for powerful, high-definition sound
  • Intuitive app for controlling your streams of music via any iOS/Android mobile device
  • Multi-room enabled system with support for a wide range of audio files, including lossless
  • Preset buttons instantly activate your favourite streams
  • Only with Raumfeld: Real Time Stereo Link for a precise sound stage
  • Energy saving standby mode uses less than 1 watt
The new Stereo M is the first 3-way streaming-enabled bookshelf speaker
For audiophile enjoyment with streaming speakers, the same acoustic requirements that apply to traditional wired speakers need to be met. This means that two identical loudspeakers in a stereo arrangement are an absolute necessity. If each of the two stereo speakers are individually controlled, as is the case with most Wi-Fi loudspeakers from other manufacturers, they will not receive the audio signal at exactly the same time. The resulting imbalance leads to a less than ideal listening experience.
With the Stereo M, Raumfeld uses its Real Time Stereo Link for the utterly synchronous playback from both speakers. This results in a harmonious and highly precise sound image with a highly differentiated deep bass range.
The original Speaker M had a very strong bass performance; the Stereo M goes a step further. We’ve given this model a dedicated woofer for bass playback. A bass reflex vent using Air Stream Bass technology ensures that the low end is not disturbed by any wind noise.
The midrange driver and tweeter are arranged coaxially, a construction that prevents differences in propagation times and approaches the ideal of a point source. This same technology can also be found in our other Wi-Fi stereo speakers, the Raumfeld Stereo Cubes, with the same result: Instruments and voices are tangibly close and precisely rendered. A waveguide for the tweeter helps create a very broad sound dispersion for an even, well-blended sound that can be appreciated from every listening position.
The days of amassing a huge amount of equipment, stacking them on shelves and low boards and cabling them together in order to appreciate high-quality music playback are over. The Raumfeld Stereo M performs the tasks of an amplifier, tuner, CD or record player and loudspeakers all in two compact enclosures and without compromise. On the contrary, thanks to a 320 watt integrated, low noise class D amplifier, the Stereo M outperforms many floorstanding stereo speakers.
A free Raumfeld App for Android and iOS devices is all you need to control the speakers including all streaming functionality. You can select a listening zone, control the volume in all rooms individually, or simply browse through your music collection or the various streaming services offered including WiMP and Spotify. An equalizer even allows you to adjust the sound in each listening zone. The Raumfeld App makes it possible to create your own playlists as well as access the playlists others have made available. Because the Raumfeld system is modular, you can expand a single pair of Stereo M speakers into amultiroom setup with the purchase of other Raumfeld devices. All can be controlled and played together thanks to the app.
4 direct selection buttons on the Stereo M mean that you are not dependent on the app to control the device. Simply save your favourite music streaming services, Internet radio or your personal music library for direct playback at the push of a button – a nice alternative for early mornings before that first cup of coffee.
TIDAL– Enjoy millions of songs in lossless sound quality
Previously known as "WiMP," TIDAL allows you to stream an enormous selection of CD-quality audio files as well as music videos - all controlled via a well-designed app. At the present time, over 25 million songs are available on WiMP.
Spotify – Access millions of songs via Spotify Connect on the Raumfeld system
Spotify is the number 1 music streaming service with the largest music catalogue. It also offers a clever recommendation service, countless playlists for every mood and occasion, personalized radio and much more. Share your music with your friends on Spotify itself or on Facebook, Twitter, or your own blog.
Napster – huge music catalogue, clever recommendations
Browse through Napster’s gigantic selection with the Raumfeld App or Controller. Their music flat rate allows you unlimited enjoyment. Over 18 million songs along with a wide selection of audio books, book readings, and other features are at your disposal.
Test Napster for 30 days for free and without obligation or commercial interruptions. Napster is available in Germany and England.
Tunein – 70,000 radio stations
Tunein allows you to listen to radio programs from around the world. Enjoy special interest channels for classic, jazz, or punk or the latest DJ mixes. Stream local radio stations throughout the house and all in the highest sound quality. The Raumfeld App allows you to save your favourite stations.
USB storage devices, NAS storage systems, DLNA/UPnP
Play music from your own music collection stored on a network, NAS storage system, or external hard drive/USB storage device. A USB storage device can be directly connected to the Connector.
Media players such as the Windows Media Player 12 or Twonky allow you to stream music stored on PCs or Macs via the Connector without loss. Raumfeld systems are also able to communicate with DLNA-/UPnP-enabled devices.
Direct Android-Streaming
The Connector can stream music saved on your Android smartphone or tablet quickly and directly - without a loss of quality.
Direct iOS streaming
The Connector can stream music saved on your Apple iPhone, iPad, or iPod directly, wirelessly, and without quality loss.
Multiroom & multimusic with extra EQ
You can combine the Controller with a Stereo S, M or One and bypass the need for a Raumfeld Base. The Connector services as a music server with 160 GB hardrive and creates an independent WLAN connection which improves the performance and speed of an existing Raumfeld setup. Depending on the quality of the WLAN, your existing router and positioning of the Connector, you will not require a Base.
In the Raumfeld App or Controller, you can define listening zones and fill these with different or the same sounds. Lossless, synchronous wireless playback is the result. You can select a different EQ setting per listening zone.
Stream via line-in
Connect your record or CD player, iTeufel Dock v3 or other auxiliary device via the line-in panel on your Connector and stream signals from these devices (in a multiroom setup) to other rooms. For example, you can play a record in the living room and stream the sound via a Connector to a Raumfeld One in the kitchen.
iTunes
If your iTunes music is on your computer, Raumfeld can access the files via the network. Please note that the files are only available to the system if the computer is turned on.
Audio formats and gapless playback
Raumfeld plays all common music formats in standard and variable bit rates. According to your preferences and convenience, you can play MP3, WAV, FLAC, OGG, Vorbis, ASD, WMA and AAC.
If there isn’t meant to be a pause in the music, you won’t hear one – that’s gapless playback.
New features per update
Raumfeld by Teufel guarantees that your system will stay abreast of changing trends because the Raumfeld software is constantly being developed. All Raumfeld system components pull the latest updates from the Internet so that you can look forward to the regular addition of new features and music services.
€ 899.99
http://www.teufelaudio.com/raumfeld-audio-streaming/raumfeld-stereo-m-p15195.html
mrkgeo
