RAUNA - Swedish hi-fi products
MODEL ABOVE IS CONTINUO REFERENCE GRANITE
Technical data: Weight 25 kg Including Cantus tonearm (4 kgs platter alone) Dimensions (bhd) 450x460x415 with dust cover open Arm hole 30 mm dia, 210 mm from platter spindle.
Made in Sweden by RAUNA, Karlskoga.
Opus 3 Cantus parallel tracking arm
Technical data Weight: 380 gm total (including 15 gms cartridge). Only 30 grams of moving parts.
Dimensions: 210x180x80 mm when mounted.
Mounting position: 220-230 mm from centre of turntable spindle. v\vskip 5mm NB.i
The Cantus can be attached to the turntable base with a small quantity of cyanoacrylate adhesive. The Cantus can be fitted to most turntables suitable for 9" or 12" arms. Made in Sweden by RAUNA, Karlskoga
Candela Valve Amplifiers
Candela is symmetrically designed and balanced. It is not sensitive to power line disturbances or electrical fields.
The design goals are to attain short signal paths and minimal signal processing. The amplifier is hand-built and "hardwired". The components included are of the highest quality.
The input stage is based on two 2493s, the long-life version of ECC 88, and are configured as two cascodes in differential operation. The output stage is based on two 5881s, the audio version of 6L6GC working in push-pull mode with the C-core output transformer.
The design is intended to promote reliable operation, long life for the product, and demand a minimum of service.
Technical specifications
Output power 2x30 watts
Dimensions 345x255x200
Weight ca 15 kg
Sensitivity 1,5v/30 watts
Base in beechwood dark varnished stain, upper part and transformer lid in anodized aluminum.
TimoleonTimoleon
