Revel Ultima Studio2
Κώστας Φ.
Price: $15,999/pair
"Conclusions
What's not to like—indeed, love—about the Revel Ultima Studio2? Almost nothing. I could point to the flimsy trap door and the less-than-overwhelming soundstage spread, though the latter was probably particular to my room. In the areas of lack of coloration, integration across the audioband, dynamic range, imaging, and soundstage depth, the Studio2s were simply outstanding. Including electrostatics that can't approach the SPLs that the Revels handled with aplomb, the Ultima Studio2s imposed less of a fingerprint on the sound than any speaker I have used. Urgently recommended, both to those in the market and to those who simply want to hear how good a loudspeaker can be."
-- Kalman Rubinson
"The Revel Ultima Studio2 offers superb engineering and measured performance for which no apology need be made. It is a worthy successor to the original Ultima Studio, which has been one of my speaker references for the past seven years." -- John Atkinson
Full Review: Stereophile.com
  • Description: Three-way bottom-ported, floor-standing loudspeaker.
  • Drive-units: 1" beryllium-dome tweeter in waveguide front plate, 5.5" inverted titanium-dome midrange driver, two 8" inverted titanium-dome woofers.
  • Crossover frequencies: 230Hz, 2kHz.
  • Anechoic frequency response: 32Hz–45kHz, –3dB.
  • Frequency response on axis: 33Hz–20kHz, ±1dB.
  • In-room response relative to target response: 31Hz–18kHz, ±0.5dB.
  • Low-frequency extension: –10dB at 21Hz, –6dB at 25Hz, –3dB at 32Hz.
  • Impedance: 6 ohms nominal, 3.7 ohms minimum.
  • Sensitivity: 88.7dB/2.83V/m (2 pi anechoic).
  • Dimensions: 46.25" (1175mm) H by 13.75" (349mm) W by 20.5" (521mm) D, all including nonremovable base.
  • Shipping weight: 140 lbs (63.5kg)
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Revel Ultima Studio2
τώρα που το δολάριο είναι στα κάτω του πόσα ευρώπουλα κοστίζει ένα τέτοιο θηρίο;
Nikos88
