Mr Spock
demokratischer - sektor
![1576049585043.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265635_97ad3fbf74eb3a68e7091f43802f93c8.png)
The Michi P5 Control Amplifier delivers the ultimate performance in audio processing with a full complement of analog and digital source inputs. Over 3 years in the making, every aspect of the P5 has been carefully crafted including the power supply, circuit design and critical component selection to ensure the highest integrity of the audio signal eliminating unwanted noise and distortion.
The Dual AKM 32-bit DACs feed the Class-A preamplifier circuit ensuring detail, accuracy and the highest musical fidelity while maintaining crucial rhythm and timing for all musical genre regardless of your listening style. These circuits are supported by an array of 17 independent voltage regulators driven from 2 custom designed and factory built toroidal transformers with low ESR smoothing capacitors to deliver ripple free current to all critical circuits.
Accuracy and detail are essential in reproducing audio and equality important is delivering music that is enjoyable and entertaining. The P5 excels in all aspects building on over 55 years of audio design experience. The bespoke in-house manufacturing facility ensures this preamplifier is built to highest of quality standards allowing it to proudly wear the Michi logo.
Automation and control system integration is easily supported with RS232 and Ethernet connections.
The Michi P5 includes MQA (Master Quality Authenticated) technology, which enables you to play back MQA audio files and streams, delivering the sound of the original master recording.
![1576049647476.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265636_b6a5fad351e18fd7c1481e381d641184.png)
INTERMODULATION DISTORTION (60Hz:7kHz, 4:1)
<0.002%
INPUT SENSITIVITY
Line Level Inputs (RCA): 160mV
Line Level Inputs (XLR): 250mV
Phono Input (MM): 2.5mV
Phono Input (MC): 250uV
Digital Inputs: 0dBFs
INPUT IMPEDANCE
Line Level Inputs (RCA): 47kΩ
Line Level Inputs (XLR): 100kΩ
Phono Input (MM): 47kΩ
Phono Input (MC): 47kΩ
Digital Inputs: 75Ω
INPUT OVERLOAD
Line Level Inputs (RCA): 12V
Line Level Inputs (XLR): 12V
Phono Input (MM): 199mV
Phono Input (MC): 22mV
OUTPUT LEVEL
Unbalanced (RCA): 1V
Balanced (XLR): 2V
OUTPUT IMPEDANCE
Unbalanced (RCA): 470Ω
Balanced (XLR): 100Ω
CHANNEL SEPARATION
Line Level Inputs: >85dB
Phono Input: >55dB
TONE CONTROLS
±10dB at 100Hz / 10kHz
COAX/OPTICAL DIGITAL INPUT SIGNALS
LPCM (Up to 24-bit/192kHz)
PC-USB
USB Audio Class 1 (up to 24/96)
USB Audio Class 2 (up to 32/384)*
*Driver Installation Required
DSD and DoP Support
MQA Support
![www.rotel.com](/forum/proxy.php?image=https%3A%2F%2Frotel.com%2Fsites%2Fdefault%2Ffiles%2Fproduct%2FP5_Front.jpg&hash=75e4b58cc0830f729925700a40f8ed19&return_error=1)
P5
The Michi P5 Control Amplifier delivers the ultimate culmination of audio performance with a full complement of source inputs. The meticulous circuit design, critical component selection and over 3 years in the making ensures the P5 meets the highest of standards allowing this preamplifier to...
![www.rotel.com](/forum/proxy.php?image=http%3A%2F%2Fwww.rotel.com%2Fsites%2Fdefault%2Ffiles%2Ffavicons%2Fapple-touch-icon-57x57.png&hash=2420ed6fce00015b329022ab3210adae&return_error=1)
Post automatically merged:
![1576049746999.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265637_8d628497738fc18509a57b61cc637f5b.png)
The stunning control and authoritative power of the Michi M8 Monoblock Amplifier is the result of a perfect balance of science meets art delivering 1,080 watts of Class AB power into 8 ohms and an astounding 1,800 watts to the most demanding 4 ohm loudspeakers. The M8 is powered by a pair of custom engineered, low noise, in-house manufactured toroidal transformers supported by 4 British patented slit foil, high efficiency, low ESR bulk storage capacitors for impactful bass with exceptional control under extreme loading conditions.
To achieve accuracy and its unsurpassed performance, the M8 is equipped with an array of 32 high current output transistors thus reducing the load on individual components and maintaining the crucial energy, rhythm and timing throughout the amplification stages. Musical expression and detailed refinement were further accomplished through acoustic tuning of all critical components and a balanced circuit design.
A high resolution display adorns the front panel supporting a peak power meter or spectrum analyzer. With XLR and RCA inputs, 2 sets of custom Michi speaker binding posts, remote control and fully featured RS232 and Ethernet connections the M8 provides ultimate installation flexibility. Power amplification at its best in the most elegant of industrial designs.
![1576049785971.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265638_924c31002fca17282f6f07196b2afb5d.png)
<0.03%
DAMPING FACTOR
200
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
Unbalanced (RCA): 1.85V
Balanced (XLR): 3V
INPUT IMPEDANCE
Unbalanced (RCA): 12.5kΩ
Balanced (XLR): 100kΩ
![www.rotel.com](/forum/proxy.php?image=https%3A%2F%2Frotel.com%2Fsites%2Fdefault%2Ffiles%2Fproduct%2FM8%2520Front.jpg&hash=11b68eb963a195a677d47562b98e98b4&return_error=1)
M8
The Michi M8 Monoblock Amplifier no-compromise Class AB amplifier delivers 1,080 watts into 8 ohms and an astounding 1,800 watts into 4 ohm loads. The design architecture ensures a smooth, accurate and relaxed delivery of the audio to even the most demanding loudspeakers while maintaining...
![1576049869233.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265639_e13fe32ca1c029743503229e760929d9.png)
The Michi S5 Stereo Power Amplifier is a best in class linear amplifier delivering 500 watts of Class AB power in 8 ohm and over 800 watts to 4 ohm loads. The dual monoblock architecture is equipped with twin, custom engineered oversized, in-house manufactured 2,200 Volt Amp toroidal transformers in individual epoxy filled enclosures eliminating noise and vibration. A bank of 4 British patented bulk storage capacitors totaling 188,000uF delivers exceptional bass energy while maintaining precise detail and control to 32 high current output transistors ensuring effortless accuracy of the timing and rhythm under even the most difficult of load conditions.
Audio performance must be engineered from product concept through production. This is evidenced in the S5 as the result of countless hours of engineering design reviews, critical component evaluation and sonic tuning. Accuracy at its best while delivering on a promise to ensure the audio provides entertainment deserving of the Michi logo.
An elegant industrial design puts the finishing touch on this amplifier with a font panel color display and Michi exclusive custom high current 5-way rhodium plated binding posts. The included remote control provides easy setup and operation with RS232 and Ethernet connections supporting all popular control systems.
![1576049919858.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265640_924c31002fca17282f6f07196b2afb5d.png)
<0.03%
DAMPING FACTOR
350
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
Unbalanced (RCA): 2.6V
Balanced (XLR): 4.2V
INPUT IMPEDANCE
CHANNEL SEPARATION
>65dB
![www.rotel.com](/forum/proxy.php?image=https%3A%2F%2Frotel.com%2Fsites%2Fdefault%2Ffiles%2Fproduct%2FS5%2520Front.jpg&hash=2352cc19ca3dbdda2231ccf38dab95f0&return_error=1)
S5
The Michi S5 Stereo Amplifier delivers 500 watts per channel into 8 ohms loads with best in class audio performance. The dual monoblock design includes twin, oversized, in-house manufactured toroidal transformers for exceptional bass energy while maintaining control and precision of the finest...
. . . εδώ η ιστορία , το θρυλικό τους phono . . .
![1576050103514.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265641_c11f76a5118a251b4524602e8c89fa6c.png)
![1576050116979.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265642_755e7520ace5ae5b7cc427259bc4a79e.png)
The PCB of the RHQ-10 is made of high-grade fiberglass with 0,1% and 0,01% tolerance metal film Vishay resistors in the signal paths, eq and NFB loop.
The first and head-amp stage is a triple parallel differential fully complementary push-pull ; the second stage is a passive pole low-pass filter ; the third is a low frequency boost and gain stage.
The output stage is a single-ended fully complementary push-pull circuit in Class A. Discrete components throughout.
One input is available, with two outputs : Fixed 1 is for connection to a passive controller or preamplifier which bypasses the volume control ; Variable is for going directly into a power amplifier ; Fixed 2 is for connection to a passive controller or preamplifier when using a moving coil cartridge of extremely low output.
The MM / MC gain & impedance selection however remains mysterious and rests on "an ingenious method to minimize any adverse effect upon sound quality often cause by mechanical switching" - anyone ?
Rotel RHQ-10 on thevintageknob.org
vintage 1990s Rotel MICHI high-end audio phono equalizer
Input sensitivity: 0.3mV (mm), 2.5mV (mm)
RIAA accuracy: 20Hz to 20kHz +-0.1dB
Output level: 0.775V
Total harmonic distortion: 0.005%
Signal to noise ratio: 75dB (mc), 90dB (mm)..............!!!
Overload: 30dB
Dimensions: 470 x 76 x 332mm
Weight: 6.8kg
![1576050399765.png](https://www.avsite.gr/forum/data/attachment-files/2019/12/265644_c3ebf7d43c416e697ac3c3d53c873812.png)
