rotel rb 1070
σε αριστη κατασταση μαυρος ασημενιος πολυ λιγες ωρεs
Continuous Power Output 2 x 130 watts
Power Configurations
Watts/Channel 2 x 130 watts
1 x 360 watts
all channels driven,
unbridged, 8 ohm load,
20 to 20k Hz, 0.06% THD
Total Harmonic Distortion
(20 Hz - 20 kHz)
cont. rated power
one-half rated power
one watt per channel 0.03%, maximum
0.03%, maximum
0.03%, maximum
Intermodulation Distortion
(at rated power, 60Hz:7kHz = 4:1 ) 0.03%, maximum
Damping Factor (8 ohms)
Input Impedance/Sensitivity 500
1.0 V / 33 kOhms
Input Overload Level
Frequency Response 5V
4Hz - 100kHz +0.5 dB, -3 dB
Signal to Noise Ratio (IHF A) 120 dB
Power Consumption: 400 Watts
Power Requirements: 115 volts, 60 Hz (U.S. version)
230 Volts, 50 Hz (European version)
Dimensions (W x H x D): 430 x 121 x 350 mm
Weight (net): 11.9 kg, 26.25 l
Απάντηση: rotel rb 1070
ωχ ναι παλι ξεχασα .αρχη στα 390ε,ανταλλαγη με nad τουλαχιστον μεγαλυτερο και με πληρωμη + απο μερους μου
DAMBO
