Πωλείται σε άριστη κατάσταση.
3x200 στα 8ohm.
Description:
Three Channel power amplifier ΤΗΧ certified // 3 x 200 watts RΜS
Τροφοδοτικό 1,4 KV @ 4 x 15.000 μ.F Caps / 80V
Both RCA and XLR inputs
Continuous Power Output (20-20 kHz, < 0.03%, 8 ohms) 200watts/ch
Total Harmonic Distortion (20 Hz-20 kHz. 8 ohms) < 0.03%
Intermodulation Distortion (60 Hz: 7 kHz. 4:1) <0.03%
Frequency Response ( + 0.5 dB. -3 dB) 15-100k Hz
Damping factor (20-20,000 Hz, 8 ohms) 500
Speaker Impedance (Normal mode) 4 ohms minimum
Signal to Noise Ratio UHF A network) 116 dB
Input Impedance/Sensitivity 32 k Ohms/1.5 volt
Power Requirements 115 Volts, 60 Hz or 230 Volts, 50 Hz
Power Consumption 600 Watts
Dimensions (W, H, D) 440 x121 x365mm, 17 3/8 x 4 3/4 x 15 3/16
Weight (net) 18,3 Kg
Τιμή 550 ευρώ
3x200 στα 8ohm.
Description:
Τιμή 550 ευρώ
1,9 MB Προβολές: 0
