Sharp AQUOS LC-37GE2 1920X1080 LCD TV
Χρήστος Ακρατόπουλος
Sharp Corporation announces the introduction into the Japanese market of the LC-37GE2 AQUOS 37V-Inch* Full-Spec High-Definition LCD TV featuring a full-spec high-definition LCD panel with resolution of 1,920 H x 1,080 V pixels. This new LCD panel brings out all the stunning image quality and detail of digital HDTV broadcasts.
The newly developed 37V-inch full-spec high-definition LCD panel features a high contrast ratio (1200:1) with increased tonality for black hues, and is capable of reproducing velvety blacks in darkened rooms and sharp, clear pictures in bright rooms. In addition, a response rate of 6 msec enables the LC-37GE2 to reproduce sharp, crisp images even of high-speed full-motion video. And, a wide viewing angle of 176° side-to-side and top-to-bottom reduces “white washout” and color changes on the screen even when viewed from a skewed angle. Users will experience impressively beautiful, high-quality images.
In addition, a newly developed Four-Wavelength Backlight that faithfully reproduces pure red by adding “crimson” to the conventional blue, green and red primary colors, allows the LCD panel to beautifully render rich, true-to-life reds, such as the ruby red of an aged wine.
Also, Sharp’s high-aperture speaker system and highly rated 1-Bit digital amplifier deliver clear, natural, high-resolution sound. And the LCD-37GE2 also offers an abundance of input/output jacks, including an HDMI (High-Definition Multimedia Interface) input jack and DVI (Digital Visual Interface) input jack, allowing users to enjoy digital video by connecting a DVD player or other audio/video equipment. Further, this LCD-based model is designed with full attention to environmental considerations, including low power consumption and the use of materials optimized for recycling. The evolved LCD panel technologies and imaging technologies brought together in this model enable Sharp to offer the LC-37GE2 as the flat-panel TV of the future far surpassing other video systems in picture quality, color reproduction, environmental performance and design.
Major Features
1. Newly developed 37V-inch full-spec high-definition LCD panel with resolution of 1,920 H x 1,080 V pixels precisely displays digital content in high-definition format exactly as broadcast
2. Four-Wavelength Backlight faithfully reproduces pure red by adding “crimson” to the conventional blue, green and red primary colors
3. Total design concept based on Sharp’s AQUOS Platform for LCD TVs
4. Crisp, clear sound thanks to Sharp’s proprietary 1-Bit digital amplifier and high-aperture speaker system
5. A wealth of input/output jacks as standard equipment, including an HDMI input jack and DVI input jack
* “V-inch” is a measure of the true size of the flat TV screen, standardizing on the length of the diagonal dimension of the actual viewing area.
Product name Full-Spec High-Definition LCD TV
Nickname AQUOS
Model name LC-37GE2
Design type Side-speaker design
Suggested retail price
(before-tax price) 546,000 yen (520,000 yen)
Date of introduction in Japan October 21, 2005
Monthly production 5,000 units
Specifications
Product name LCD color TV
Model name LC-37GE2
LCD panel Screen size 37V-inch
(82.0 H x 46.4 V cm; 94.0 cm on the diagonal)
Drive system TFT (thin-film transistor) active-matrix drive
Dot count 1,920 H x 1,080 V pixels
Screen brightness 450 cd/m2
Viewing angle Vertical: 176°, horizontal 176° (CR=10)
Backlight source Internal (built-in fluorescent tube)
Speakers 6.5-cm diameter x 4, 2.0-cm diameter x 2
Max. audio output (JEITA) Total 20.0 W (10.0 W + 10.0 W)
AC power supply voltage 100 V AC, 50/60 Hz
Power consumption 253 W
Standby power consumption 0.3 W
Main unit dimen-sions
Display section only 93.0 W x 11.0 D x 57.7 H cm
With speakers 108.7 W x 11.0 D x 57.7 H cm
With speakers and table stand 108.7 W x 30.4 D x 65.3 H cm
Main unit weights Display section only Approx. 21.0 kg
With speakers Approx. 24.5 kg
With speakers and table stand Approx. 29.0 kg
TV reception channels
VHF channels 1 to 12
UHF channels 13 to 62
Cable TV channels 13 to 63
Digital BS channels 000 to 999
Digital CS110° channels 000 to 999
Digital terrestrial channels 000 to 999
(with cable TV pass-thru)
Input/output jacks
Composite video input (4 sets)
S2 video input (2 sets)
D4 video input (2 sets)
HDMI input
DVI-I input (with audio input jack)
Center speaker input
Monitor output (combined with S2 jack, doubles as video input 4 and recording output jack)
Headphone output
Digital audio output (optical)
External speaker
i.LINK (TS) S400 (2 sets)
PC card slot
B-CAS card slot
Terrestrial analog antenna input
Terrestrial analog antenna output
Terrestrial digital antenna input
BS/CS110° antenna input
Telephone line (56 kbps)
LAN (10Base-T/100Base-TX)
Video controller
AC power input
Accessories
Table stand (assembled with main unit)
Speakers (1 set)
Wireless remote controller
AAA dry cell battery
AC power cord
Antenna cable
BS/CS110° antenna cable
Telephone cable
B-CAS card
Modular splitter
Video controller
Tipover-prevention hardware (1 set)
Cable clamp set (1 set)
Operation manual
Warranty card
akis4525
