Έχει κανείς προσωπική εμπειρία από sherwood av receiver ?
Ψάχνωντας για κάτι φθηνό έπεσα πάνω τους σε ένα μαγαζί και
κουβέντα στην κουβέντα είδα το συγκεκριμένο μοντέλο που έρχεται
όμως από Μάρτιο μάλλον. Αξίζει να περιμένω?
Πάντως στα spec είναι πολύ καλός ....
* 100 Watts per Channel from 20 Hz-20 kHz in Stereo Mode, 8 ohms, with <0.05% THD
* 100 Watts per Channel x 7 in Surround Mode
* 4 in 1 out HDMI 1.3 switching
* Scales all video to 720p/1080i/1080p
* Faroudja 2301 Scaler/Deinterlacer
* Decodes DTS Master Audio HD and Dolby Tru HD
* DTS-ES Discrete and Matrix
* DTS-96/24 DTS
* DTS NEO-6 Cinema and Music
* Dolby Digital EX
* Adjustable Dolby Pro Logic IIx
* Dolby Headphone Layers 1, 2, 3
* Digitally Re-Masters PCM input to 96 kHz/ 24-bit
* Automatic Format Detection
* 192 kHz 24-bit DAC’s for all channels
* Dolby Virtual Speaker
* Pure Audio Mode
* Crossover frequency 40 to 250 Hz
* A/V Synch delay by input
* Firmware upgradeable
* SNAP 12-band EQ per channel
* RS-232 and USB
* Universal Video™ upconverts composite and S-Video to Component Video
* 4 Optical and 2 Co-ax Digital Inputs
* Digital Output
* On Screen Display (available from all video outputs)
* RF + IR Learning remote with LCD display
* Programmable Input Labeling
* Crystal 32-Bit DSP processor
* 8 DSP Modes
* 7.1 channel direct input
* 8 Pre-Amp Outputs (L, C, R, L. Surround, L Rear Center Surround, R Rear Center Surround, R. Surround, Subwoofer)
* Room 2 A/V Output w/ fixed/variable audio level, S-Video
* Automatic 7.1 to 5.1 + Stereo
* Lockable "Installer Memory"
* Rear Panel Room-2 IR control with 1 input and 1 output
* Dedicated Room 2 Remote
* 12-Volt Trigger
* 3 HDTV-Ready Component Video Inputs
* Component Video Output
* 4 Rear Panel Audio/Video Inputs
* 4 Audio Inputs
* Front Panel A/V Input Including S-Video and Optical Digital
* Cinema EQ
* Tone Defeat
* Automatic set-up for speaker level and distance
* Channel Level Memory
* 10-step Dynamic Range Control
* Totally Discrete Amplifier Stage (TDAS)
* Heavy Duty Speaker Binding Posts
* XM Connect and Play XM Neural Surround
* 4 Gang FM tuner
* Preset Scan
* 30 XM Presets
* 30 AM/FM Station Presets
* Digi-Link III
* Sleep Timer
* Aluminum Front Panel Dimensions: 17 3/8" W x 6" H x 15" D
* DTS-96/24 DTS
* Dolby Digital EX
* Pure Audio Mode
* RS-232 and USB
* Digital Output
* 8 DSP Modes
* 12-Volt Trigger
* 4 Audio Inputs
* Cinema EQ
* Tone Defeat
* 4 Gang FM tuner
* Preset Scan
* 30 XM Presets
* Digi-Link III
* Sleep Timer
107,9 KB Προβολές: 19
