Formats, Processing and Outputs
Media
Formats DVD-Video, CD Audio, Video CD (VCD), CD-R/RW, DVD-R/+RW
Video
Formats NTSC (Interlaced & Progressive outputs)
PAL (Interlaced output ONLY)
Audio
Formats
MPEG1 (VCD), MPEG2 (DVD), Linear PCM Digital Audio (CD),
Dolby Digital 5.1 (AC-3), Dolby Digital Surround EX,
DTS Digital Surround 5.1TM and DTS-ESTM 6.1
Video
Processing
10-bit/54MHz oversampled video with active current-to-voltage converter, phase accurate analog filtering and Analog Devices video op-amp (AD8073)
Audio
Processing
Scientific Conversion SC982 digital audio transformer for jitter & noise reduction · Optional BurrBrown PCM1730E 24-bit/192kHz DAC with 8X oversampling digital filter and BurrBrown audio op-amps (OPA2604)
Video
Outputs Composite Video (CVBS)
on an RCA Connector Line output level
1.0Vp-p
S-Video (Y/C)
on a 5 pin mini-DIN
Connector Y output level
C output level
1.0Vp-p
0.300Vp-p PAL
0.286Vp-p NTSC
Component Video
(interlaced)
on RCA Connectors
Y output level
PB output level
PR output level 1.0Vp-p
0.7Vp-p
0.7Vp-p
Serial Digital Interface
(SDI) on BNC connector
0.8V @ 75 ohms
Progressive
Video
Outputs
Component Video (480p)
on BNC Connectors
Y output level
PB output level
PR output level
1.0Vp-p
0.7Vp-p
0.7Vp-p
Digital Video Interface
on 24-pin DVI-D
connector (480p)
LVDS
Audio
Outputs Optional 2-channel Analog Single-ended 2.0 V @ 50 ohms
Digital (2-channel &
multi-channel) S/PDIF RCA
Optical Toslink 0.5 V @ 75 ohms
660nm wv
Video Specifications
Horizontal Scan Frequency 31.5kHz
Video Frequency Response ±0.5dB to 5.5MHz
Video Signal-to-noise ratio > -60dB
Video Differential Phase >0.5°
Video Differential Gain >0.1dB
Supported Aspect Ratios
Anamorphic 16:9
LetterBoxed 4:3
Pan & Scan 4:3
DVD Linear audio specifications (EIAJ, A-weighted, fS = 24-bit/96kHz)
Frequency response 0.7Hz - 22kHz
Signal-to-noise ratio 117dB
Dynamic Range 117dB
Channel Separation 113dB
THD + N 0.0006% @ 0dBFs
CD audio specifications (EIAJ, A-weighted, fS = 16-bit/44.1kHz)
Frequency response 0.7Hz - 20kHz
Dynamic Range 117dB
Channel Separation 115dB
THD + N 0.0004% @ 0dBFs
Pass-band Ripple ±0.002dB
Stop-band Attenuation < - 82dB
Miscellaneous Information
Available Faceplate Finishes Black and Silver
Remote Control Full-Function All-Aluminum
Display Type VFD (Vacuum Flourescent Display)
Front Panel Controls
Display · Stand by · Shuffle · Repeat ·
FTS · Scan · Open/Close · Stop · Play ·
Previous Track · Next Track · Pause
Rack mount size 3 spaces
Power Consumption 12 Watts
AC Power Requirements 120V / 60Hz 240V / 50Hz
Fuse Replacement 4A short fast blow (120V & 230V)
Warranty (USA & Canada) 1 yr - transport / 5 yrs - electronics
Shipping weight 26 lbs / 12 Kg
Dimensions (W x H x D) 19 x 6-1/2 x 14 in. (48 x 16.5 x 35.5 cm.)
