Aπό τον Καναδά...
Line Level Integrated Amplifier: SA-34 SB
2 line level inputs
Noble volume potentiometer
Single-ended, 0 NFB, direct-heated triode [4 wpc/8 ohm]
2 x 12AX7 driver, 1 x 5AR4 rectifier, 2 x EL34 output
Electroharmonix EL34
Proprietary transformers
bronze chassis with chrome plate
Song Audio 1.5m 98% pure silver power cable with Wattgate 320 IEC
and Marinco hospital grade AC connector
Line Level Preamplifier: SA-1
3 line level inputs
Noble volume and balance potentiometers
Single-ended, 0 NFB
3 x 12AX7 output (control unit), 1 x 5AR4/GZ34 diode (power supply unit)
Power Amplifier: SA-300 MB
Single-ended, 0 NFB, direct-heated triode [8 wpc/8 ohm] monoblocks
2 x 6SL7 driver, 2 x 5U4 rectifier, 2 x 300B output
Electroharmonix or JJ Electronics (Tesla) 300B
Song Audio 1.5m 98% pure silver power cables with Wattgate 320 IEC
Acoustic Monitor: Type II Silk DM
17 cm Davis Acoustics kevlar LF/MF
28 mm ScanSpeak HF
3rd-order vented box
90 dB/2.83 v/m, 60 Hz (-3db)
JA Michell rhodium binding posts
42 x 22 x 30 cm (h w d)
2 line level inputs
3 line level inputs
Single-ended, 0 NFB
28 mm ScanSpeak HF
