Sonus Faber Stradivari Homage loudspeaker
REVIEW:
http://www.stereophile.com/loudspeakerreviews/105sonus/
Description: Three-way, floorstanding loudspeaker. Drive-units: Scan-Speak 1" silk ring-radiator tweeter, Audio Technology 6" pulp-cone midrange unit, two SEAS 12" aluminum/magnesium-cone woofers. Crossover frequencies: 300Hz, 4kHz. Frequency range: 22Hz–40kHz. Sensitivity: 92dB/W/m. Nominal impedance: 4 ohms.
Dimensions: 53.5" (1360mm) H by 25.6" (650mm) W by 19.7" (500mm) D. Weight: 165 lbs (75kg).
Finishes: violin red, slate gray.
Price: $40,000/pair.
Ίσως μαζί με το Sonus Faber Amati Homage τα ομορφότερα ηχεία που υπάρχουν.
Για τον ήχο ας μιλήσουν άλλοι.
Να και ένα set up:
Turntable Scheu Premier MK2 turntable - 80mm platter, transparent, 12" one-arm plinth version
Tonearm Schroeder The Reference tonearm - in bocate finish, 12" version
Phono Cartridge Audio-Technica Reference Model
Phono Stage Pass Labs XONO
CD player Esoteric DV-50 universal player
Loudspeakers Sonus Faber Stradivari Homage
Preamplifier Pass Labs X1
Power Amplifiers Pass Labs X600 monoblocks
Eleni_29
